79 kz650sr/air inj.sys.
- TODDSTER
- Die Hard & Live Free
26 Oct 2008 17:42 #243975
by TODDSTER
KZ 78 650 SR D1a W/78 Quick silver 3/4 stock fairing, new dunlop rubber frnt. & back, new jcw rear shocks, new progressive frt. fork springs & 1 ground-hog to my credit.(ouch)
TODDSTER in N.Western PA
Kawi Strong w/windshield in my face
79 kz650sr/air inj.sys. was created by TODDSTER
Can i put a 79 motor w/air injection sys(kz650sr) into 78 frame & if I can how do I hook
up air injection system without air inj.frame.:huh: Would it just be a matter
of changing valve covers on top of motor or something else or not possible at all?:dry:
Thanks in advance!
Thanks in advance!
- steell
27 Oct 2008 04:44 #244032
by steell
Replied by steell on topic 79 kz650sr/air inj.sys.
Simplest way is to hook the two ports on top of the cam/valve cover together with a short piece of hose. You can do away with them altogether, but that gets more complicated.
- TODDSTER
27 Oct 2008 08:52 #244054
by TODDSTER
Replied by TODDSTER on topic 79 kz650sr/air inj.sys.
Kool, thanks for the info "steel". I didn't know if you could do that.
I thought it had to have outside air access for the reeds & exhaust ports. Thanks again
- Buda
27 Oct 2008 09:39 #244057
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic 79 kz650sr/air inj.sys.
Would putting a hose between the ports work for an 82 1000? All of the stuff up there is real ugly.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- steell
