Z1A - Z1000 cylinders- Wiseco 1075 Kit
- stever
26 Oct 2008 07:49 #243881
by stever
Z1A - Z1000 cylinders- Wiseco 1075 Kit was created by stever
As the title says I have a Z1A which runs a z1000 barrells and cylinder head. I am putting a 1075 wiseco kit on it with the fibre wiseco head and base gaskets. Do I need the O rings that fit round the base of the cylinders or not. Cos when I took it apart there werent any?
Are there any other o rings that fit round the studs at all?
- Old Man Rock
- Thank you received: 225
26 Oct 2008 08:10 #243884
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Z1A - Z1000 cylinders- Wiseco 1075 Kit
When you took off the cylinder base gasket, is it a 1 piece gasket?
This was just discussed in a posting where I asked in regards to the two different gaskets I received. One being a 1 piece and the other (OEM) was a two piece gasket...
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=241829
Hope this helps...
OMR
Hope this helps...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- stever
26 Oct 2008 10:43 #243903
by stever
Replied by stever on topic Z1A - Z1000 cylinders- Wiseco 1075 Kit
Hi old man, I had read that thread and found it usefull. However I am talking about the gasket between the cylinders and the crank case, not the head gasket.
There are 4 o rings round the base of the cylinder liners and its those that I want to know about.
For the head gasket I am going to use the 1 piece fibre gasket that wiseco provided and fill the cam chain tunnel o ring groove with silicone.
- APE Jay
- Banned
- Thank you received: 58
27 Oct 2008 10:21 #244059
by APE Jay
Replied by APE Jay on topic Z1A - Z1000 cylinders- Wiseco 1075 Kit
Whenever we put larger sleeves in the KZ blocks, there is no room for those o'rings, so we just leave them out. Never been an issue.
Jay
Jay
- stever
27 Oct 2008 11:47 - 27 Oct 2008 11:49 #244075
by stever
Hi Jay,
Its a standard z1000 block and sleeves on a Z1A 900 crankcase.
I will use the Wiseco gasket and I am using your studs and bolts to hold it all together.
Would you not bother with the O rings with this set up then?
Last edit: 27 Oct 2008 11:49 by stever.
- timebomb33
- Thank you received: 10
27 Oct 2008 16:56 #244124
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Z1A - Z1000 cylinders- Wiseco 1075 Kit
i've built lots of stock block motors some i put them in some i've left out never seemed to make any differance one way or the other,if you get them in a gasket kit it can't hurt to put them in.
