89 750 engine - non interference?
- franknsr
25 Oct 2008 08:02 #243726
by franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
89 750 engine - non interference? was created by franknsr
I just picked up a 80 ninja 750 frame and engine off ebay because I need some parts for yet another project. This bike was performing a wheelie when it locked up. Good for me because I need tranny parts.
I pulled the valve cover off and found an adjuster came loose and jammed then broke the timing chain. When I pulled the head I expected to find massive carnage, bent valves and the like but no. Everything looks great.
Does anyone know if this a non interference engine? It looks so good I’m considering replacing the timing chain and using the whole thing.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- steell
25 Oct 2008 09:27 #243739
by steell
Replied by steell on topic 89 750 engine - non interference?
I have no idea if it's a non-interference motor, but you're in an ideal position to determine if it is.
There are two possible forms of interference, valve to valve and valve to piston, so bolt the head back on it, rotate the intake cam until a valve is fully open, then rotate the crank. If nothing hits, rotate the exhaust cam till the exhaust valve in the same cylinder is wide open, then rotate the crank again.
If nothing hits after doing all the above, then you have a non-interference motor
- franknsr
25 Oct 2008 13:45 #243774
by franknsr
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Replied by franknsr on topic 89 750 engine - non interference?
Duh! Why didn't I think of that?
Thanks.
Thanks.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- guitargeek
- Thank you received: 50
25 Oct 2008 14:04 #243775
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic 89 750 engine - non interference?
Kawasaki made a Ninja in 1980?
- steell
25 Oct 2008 14:57 #243783
by steell
guitargeek wrote:
Since the thread title said 89, I figured the 80 was just a typo.
- franknsr
25 Oct 2008 17:07 #243796
by franknsr
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Only in my mind. I meant 1989, but the "0" is a little to close to the "9" on the laptop for my fat little fingers.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- guitargeek
25 Oct 2008 17:23 #243798
by guitargeek
