J engine bolts in KZ?
- Exitpupil
24 Oct 2008 17:27 #243605
by Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
J engine bolts in KZ? was created by Exitpupil
Sorry if this is a novice question, but I tried the search function for an hour/ Will a J 1100 engine bolt directly into a KZ 1000? Thanks.
- StreetfighterKz
- Thank you received: 117
24 Oct 2008 17:49 #243613
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic J engine bolts in KZ?
It is not a direct bolt on. The J model uses two front engine mounts compared to the Z1/Kz engine that only uses one front engine mount. You can mod your frame to take the J model with relative ease but not a remove/replace procedure.
Later, Doug
Later, Doug
1989 Vmax
