thrust washer mod for the j
- Buda
24 Oct 2008 10:16 #243548
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
thrust washer mod for the j was created by Buda
What is it and how can i do it?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- APE Jay
- Banned
- Thank you received: 58
24 Oct 2008 22:43 #243677
by APE Jay
Replied by APE Jay on topic thrust washer mod for the j
You need to call Stan gardner at Gardner racing.
Jay
Jay
- donthekawguy
- Thank you received: 8
25 Oct 2008 04:01 #243692
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic thrust washer mod for the j
Thomas I think your thinking a little too much about the strength of these motors. All the thrust washer mods and super-heavy duty stuff only needs to be done with high power, high buck motors. Any big kz motor will be bullet proof with a welded crank, APE studs, main cap and new cam chain. You can dump a ton of money into making the bottom end worthy of top fuel but you will never come close to needing it. Don't get me wrong, I'm a big fan of having a strong bottom end, only because it will save you from having to go in again to have the crank welded or whatever if you want to go bigger in the future. But putting 3 or 4 thousand into mods you will never need is a waist when you can spend that money where it is needed-in the head and carbs. Don't worry about how strong the cases are. they are plenty tough and will hold up to whatever you throw at them.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Buda
25 Oct 2008 09:47 #243744
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic thrust washer mod for the j
Thanks for the information guys
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
