Exhaust tuning complete
- Exitpupil
23 Oct 2008 12:03 - 23 Oct 2008 12:06 #243401
by Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Exhaust tuning complete was created by Exitpupil
I finally finished my exhaust tuning. I was inspired by some posts and comments by forum members. I have a KZ1075 (10.25:1), K410 cams, high velocity ported head, BS34 carbs, and V&H 4 into 1 exhaust. I removed the exhaust baffle and noted more top end power but with a stutter from 2K-4K rpm. So I bought a V&H performance baffle and the bike ran great, pulling smooth and strong from 2K-11K rpm, but with considerable noise increase over the street baffle. The street baffle was 1.5" and the performance baffle was 2" and also shorter allowing a larger expansion area between the collector and the baffle. Here is a pic of the 2" baffle (top)homemade baffle(mid) and the 1.5" street baffle(after cutting in two)
Both V&H baffles had abrupt transitions into the exit pipe. So I bought a long mild steel transition from Burns Stainless Steel. I also bought some 1.625" perforated screen pipe. I made my own baffle using the long transition modified to fit the 1.625 pipe welded to the perforated 1.625 pipe thinking the smooth transition with slightly larger pipe would give good scavaging and reduced noise. I also made a special long shaft rotary cutting burr and removed horrible interior overhanging lips at the megaphone joint welds. Well it worked! I still have the power of the 2" baffle with a noise level much closer to the 1.5" pipe. Time to ride ride ride.
Last edit: 23 Oct 2008 12:06 by Exitpupil.
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
23 Oct 2008 12:09 - 23 Oct 2008 12:10 #243404
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Exhaust tuning complete
You need an objective opinion.
BRING IT TO ME!!!
Nice to see the finer points being addressed.
Vid....? Ah go-on....please?
BRING IT TO ME!!!
1980 KZ500 B2
Last edit: 23 Oct 2008 12:10 by SPARKY47.
- PLUMMEN
- Thank you received: 104
23 Oct 2008 12:44 - 27 Oct 2008 05:23 #243414
by PLUMMEN
Replied by PLUMMEN on topic Exhaust tuning complete
back in my day this was how we tuned the exhuast in the school parking lot!school buses got the big baffles ,while mr z's stationwagon got the smaller baffle!:woohoo:
Last edit: 27 Oct 2008 05:23 by PLUMMEN.
- guitargeek
- Thank you received: 50
24 Oct 2008 18:09 #243616
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic Exhaust tuning complete
Very interesting...
- davel
24 Oct 2008 18:40 #243621
by davel
Replied by davel on topic Exhaust tuning complete
Nice job Will! Can you post another image showing the right side of the baffles where you welded the transition tube. On the image you posted I can only see the exit side of the baffle. Thanks.
- guitargeek
24 Oct 2008 22:41 #243676
by guitargeek
Also, how about a couple shots from different angles, and with a measuring tape next to them.
Good work!
Good work!
