fragile J motor
- Buda
Thanks Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- wiredgeorge
I would guess this fragile tag came from the boy-racer bunch. They flog an engine and abuse it and if it blows up pretty much the same way each time, the part that caused the engine to blow will be picked out as the culprit. The same engine, on the street and used by a sane person may never have an issue. I would guess folks have you worrying unnecessarily... keep in mind the cop bikes which endured hard use have the J motor (82 to 95).
- Buda
Thanks George
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- RonKZ650
- Thank you received: 240
- PLUMMEN
- Thank you received: 104
- APE Jay
- Banned
- Thank you received: 58
When we were doing the top fuel thing with the late Elmer Trett, we knew to stay away from those heads. Used the old style KZ until the billet head was finished.
Jay
- kano
- Not Another Bloody Limey!
cheaper than a plum turbo!
- darmahsd
This was never a problem until you dual plugged them and then milled them for max compression. They would split down the middle like a log. You have probably seen some old race heads with gussets welded between the cam banks.
Jay
I don't mean to hijack this thread, but the subject was brought up.
Should I stay away from dual plugging my J?
I was going to post a thread asking who still dual plugs a KZ or J head. I'm not going racing, but just thought a dual plug head will let me run cheap s&%t fuel without detonating. I need to stick with high test now. Any thoughts on this?
Stephen
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
