which year KZ engine is the best to have?
- addycml
If I am looking for a KZ, which year KZ should be the best to having and the engine is more potential to mod up for more power?
AL
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Thank you received: 797
- addycml
What means 4's? I hope a good streetable bike!
I want the cc between 1100 to 1200cc with stock block.
Dose 77 KZ1000 is good?
Or a 79 Z1R?
I see in japan have a lot called Mark II Z1000. Are these als good?
- RonKZ650
- Thank you received: 240
- racer54
- Thank you received: 114
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- addycml
Item no. 140266704780 in ebay at US$2700
Dose this one a good indication price at this condition of 1977 KZ1000?
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- donthekawguy
- Thank you received: 8
I'll insert my personal opinion on the 1000s. The 79-80 is the strongest, best KZ1000 engine. This includes the MKII and shaft, 1980 only on the LTD and Z1R. The 77-79 LTD and 77-78 KZ1000s and 78 Z1R were second best, the 81-up J coming in last. Yes the J was the fastest, but also the most fragile and weakest of the KZ1000 line in the real world.
I agree with Ron about the 79-80 shaft motors. They seem to have the thickest castings and more "ribs" in the lower case. You just need to convert them to chain drive and you can go as big as you want. Or you can just a set of these and make all the power you can afford.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Buda
Ron what about the J is fragile? I have an 82 KZ1000ltd and would like to know.I'll insert my personal opinion on the 1000s. The 79-80 is the strongest, best KZ1000 engine. This includes the MKII and shaft, 1980 only on the LTD and Z1R. The 77-79 LTD and 77-78 KZ1000s and 78 Z1R were second best, the 81-up J coming in last. Yes the J was the fastest, but also the most fragile and weakest of the KZ1000 line in the real world.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- PLUMMEN
- Thank you received: 104
