which year KZ engine is the best to have?
22 Oct 2008 18:33 #243287 by addycml
Hi, I am new to KZ. May I ask here that:
If I am looking for a KZ, which year KZ should be the best to having and the engine is more potential to mod up for more power?
AL
22 Oct 2008 18:36 #243288 by 77_650B1
Replied by 77_650B1 on topic which year KZ engine is the best to have?
As far as I know, all the 4's are great and easily modded with success. Its just a question of what kind of power you want.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
22 Oct 2008 19:13 #243293 by 531blackbanshee
Replied by 531blackbanshee on topic which year KZ engine is the best to have?
what cc do you want to build to?
22 Oct 2008 19:25 #243296 by addycml
Replied by addycml on topic which year KZ engine is the best to have?
Hi,
What means 4's? I hope a good streetable bike!
I want the cc between 1100 to 1200cc with stock block.
Dose 77 KZ1000 is good?
Or a 79 Z1R?
I see in japan have a lot called Mark II Z1000. Are these als good?
22 Oct 2008 20:16 #243308 by RonKZ650
Replied by RonKZ650 on topic which year KZ engine is the best to have?
I'll insert my personal opinion on the 1000s. The 79-80 is the strongest, best KZ1000 engine. This includes the MKII and shaft, 1980 only on the LTD and Z1R. The 77-79 LTD and 77-78 KZ1000s and 78 Z1R were second best, the 81-up J coming in last. Yes the J was the fastest, but also the most fragile and weakest of the KZ1000 line in the real world.
22 Oct 2008 20:17 #243309 by racer54
Replied by racer54 on topic which year KZ engine is the best to have?
Different models/motors have advantages and disadvantages to them. Are you going to dragrace it? Only street? What style riding you plan to do? How much you willing to spend on your project? What kind of pwer you looking for? Lots of bottom end...high HP at any cost? With all the posiblities, there will be as many opinions as there are ways to build and which bike to use. Really boils down to what model you have and working with that bike and it's advantages/disadvantages. Early Z's frames aren't as strong as the later 70's frames. Later 70's motors are stronger but use heavier components in areas and don't rev as fast. Most of the motor parts interchange and most of the body parts/ frames/ etc. can be changed around. If this is going to be mainly a streetbike, just find one in good shape to start with and build around what it has and what you want to end up with. Do you have a particular style you like...as in Z1 or Z1R or MK11 or GPZ look? Take a look at the bikes in the Gallery and see if any grabs your attention and then go from there. Lots of way to go and only you can decide what look of bike gets you there. They are all good bikes to work with and as you can see, we all have our favorites.Find you style/look and build your motor.
22 Oct 2008 20:41 #243315 by timebomb33
Replied by timebomb33 on topic which year KZ engine is the best to have?
my race bike has a gpz head, aftermarket block, the crank has a mk11 center pin, j-rods the trans mission was built up from three different units,the clutch is from a 1975 zi-b and the cases are from a 1978 kz1000. enough said
I THINK MY POWERBAND BROKE
22 Oct 2008 21:13 #243321 by addycml
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...ZMotorcyclesQQ_fviZ1
Item no. 140266704780 in ebay at US$2700
Dose this one a good indication price at this condition of 1977 KZ1000?
22 Oct 2008 21:21 #243322 by 77_650B1
Looks good to me. Some might call it high, but I've seen much worse bikes for more.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
22 Oct 2008 23:16 - 22 Oct 2008 23:30 #243331 by donthekawguy
Replied by donthekawguy on topic which year KZ engine is the best to have?
I agree with Ron about the 79-80 shaft motors. They seem to have the thickest castings and more "ribs" in the lower case. You just need to convert them to chain drive and you can go as big as you want. Or you can just a set of these and make all the power you can afford.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Last edit: 22 Oct 2008 23:30 by donthekawguy.
22 Oct 2008 23:42 #243332 by Buda
Ron what about the J is fragile? I have an 82 KZ1000ltd and would like to know.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
23 Oct 2008 01:16 #243340 by PLUMMEN
Replied by PLUMMEN on topic which year KZ engine is the best to have?
theres nothing wrong with any of them including the j-motor,itjust depends onwhat you have to workwith and what you want to spend.remember the best motor is worthless without a good chassis!B)
