- Thank you received: 1
KZ1000
- HOGEATER
- Been riding 2 wheels since 1965,
21 Oct 2008 13:51 #243066
by HOGEATER
KZ1000 was created by HOGEATER
I thought I bent a valve so I pulled the head to change and found I had copper head gaskets, I'm not the original owner so I don't know if this is still stock bore . I measured the best I could with a caliper and got 2.870 for bores and the gaskets are 2.95 with RC ENG on them. I checked the stock head gaskets and they seem to me to be too small for this bore. The reason I thought I dumped a valve is because I had alot of blowby noise thru the #1 carb. The engine still would run without any knocks or clangs.
Could someone give me some insight on what size engine I may have here..
Thanks
Chuck
Thanks
Chuck
- 77_650B1
21 Oct 2008 13:57 #243067
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic KZ1000
Looks like you've got an 1100cc engine there. Beyond that I cant help.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- MFolks
- Thank you received: 540
21 Oct 2008 14:26 #243070
by MFolks
Replied by MFolks on topic KZ1000
The copper head gasket can be used over and over as long as it is intact(not torn or broken). Take a propane torch and heat it to cherry red and let it cool. This aneals or softens the copper. The same thing can be done for the copper oil drain gaskets on cars and motorcycles.
- Becker
- The Doctor Will Rise Again
21 Oct 2008 15:02 - 21 Oct 2008 15:03 #243077
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic KZ1000
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Last edit: 21 Oct 2008 15:03 by Becker.
- Jack
- Thank you received: 7
21 Oct 2008 17:42 #243119
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic KZ1000
My guess is it's an RC Eng. 1197 cc. kit ( 1200 ) 2.875 " is roughly 73 mm. You'll probably notice the pistons have a higher dome than stockers with valve pocket reliefs cut into the tops. Good pistons,had lots of RC stuff in my bikes over the years.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- APE Jay
- Banned
- Thank you received: 58
21 Oct 2008 22:24 #243163
by APE Jay
Replied by APE Jay on topic KZ1000
May be very hard to find rings for it if you pull the barrels.
Jay
Jay
