- Thank you received: 1
sputtering in cold weather...a lot
- LP440
What do you guys think?.....low on gas and hit some moisture in the tank?.....had the choke open too long?....oil too thick?.....just too damn cold?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Thank you received: 2098
low on gas and hit some moisture in the tank? Nope. Because fuel level would not prevent any moisture from settling to bottom, as gasoline floats on water.
had the choke open too long? Maybe. Could have possibly fuel-fouled a plug.
oil too thick? Don't think so, at least not after running two miles.
just too damn cold? Nope. Would require longer warm-up, but bike performance should actually benefit.
Would assure air filter is clean, and (if applicable) not over-oiled.
Good Luck!
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- LP440
OK...I agree with all....but I am a little confused by this one......am I understanding that the only way you can have a moisture problem is if you run out of gas?.....
This may sound dumb...but I was just wondering if the tank being in an inclined position going up hill may have had something to do with the bad fuel hitting the carbs.....its just a wild ass guess....but after I turned around and went down hill....the problem went away for good......I took it out last night for a ride to get gas and had no problems....before or after the fillup.
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- wiredgeorge
- kawsakiman
- Thank you received: 6
you said you were on a steep incling then it started to sputter.
you probally uncovered the mains and it was starving for fuel.
if it ran fine on a level surface but sputters going uphill, that is where i would check first.
- MikePotter86
- Two wheels move the soul.
As many can attest, I am far from an expert, but if your petcock is like mine( I think we have the same gas tank/petcock setup) on an uphill with low fuel, the gasoline all situates real of the petcock, and you lose fuel pressure.
See if switching to reserve helps at all, this way you'll know if it is a low fuel issue before you go tearing into your carbs.
Michael L. Potter
1981 KZ 750 LTD
South Lyon, MI/ Bloomington, IN
www.flickr.com/photos/potterm/
Regardless of fuel level inside tank, any water will sink to the bottom and pass on through the petcock.
The manual (non-vacuum) petcocks have a sediment bowl where any water is supposed to collect without going on through the fuel line toward the carbs. With sediment bowl fitted, routine maintenance includes unscrewing it and dumping it and cleaning the round fuel filter screen which sits atop the sediment bowl.
Imo, the tank fuel level alone (high or low) is immaterial to volume or "pressure" of fuel flow from the tank (provided the cap vent is functional). In other words, starting with a full tank (and functional vent or cap ajar), flow from the petcock remains steady and unchanging until the tank empties.
The peanut gallery has spoken. :lol:
Good Luck!
- LP440
Good Luck!
OK...sorry...I misread what you originally said....I took it as the water would stay up....I just read it too fast....but now I totally agree.....I just think I had some moisture that made it to the carb for just a short time......the bike seems to be ok now....with the exception that it is 27 years old of course...lol....still runs good and is very reliable though......
Thanks to all you guys.....this forum is just as helpful as a few years ago when I was posting here. I plan to check in regularly again to hopefully help out if I can and pick your brains.
