- Thank you received: 109
clutch grabs
- mark1122
- Keep twisting it
if i am at a stop light it will not engage smoothly. it feels grabby. if i let it out a bit it will start to engage then as i continue to let it out nothing happens, then a bit further out it will grab hard?
I oiled the cable this morning and it continues to get worse.
Any ideas?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
I THINK MY POWERBAND BROKE
- mark1122
- Keep twisting it
it worked fine till now.oil temp guage shows 220*F after a cruise today.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
- Thank you received: 2098
This adjustment may not help if grab isn't being caused by heat from slippage, but won't hurt.
Good Luck!
- timebomb33
- mark1122
- Keep twisting it
I have a thermometer in the oil gallery plug.
I guess I’ll just have to find the time to take it apart and check the actuator and plates.
I thought i would have too . I was just hoping there was some simple answer . lol. not usually.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Sandy
- Fly High,Tony
- Thank you received: 13
1977 KZ1000 A-1
- Mark Wing
- Thank you received: 22
Yorba Linda Cal.
- Sandy
- Fly High,Tony
1977 KZ1000 A-1
- RonKZ650
- Thank you received: 240
If not already done, would perform clutch push rod adjustment)
Probably already been done. That's exactly why the clutch is all messed up.
- mark1122
- Keep twisting it
I removed the APE clutch plates, and heavy springs. The APE plates have 2 more plates than stock.Therefore the fiber plates are thinner. I noticed that the outer fingers of the fiber plates have worn grooves into where they contact the basket. These fingers if u will , must slide on the basket as they move in and out. the extra torque of my 1327cc's has worn these grooves so the plates grab as they try to travel.The springs have also started to ware grooves into the holes were they reside.
I put the stock plates and springs back in and ran it up and down the driveway. It seems fine now , but a longer ride is needed to be sure.
i will have to remove the basket and file the ridges smooth to complete the job over the winter.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
