- Thank you received: 13
Engine turns over hard when hot, any ideas?
- harm
- Tom
18 Oct 2008 14:21 #242458
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Engine turns over hard when hot, any ideas? was created by harm
I usually don't start my bike when its warm because I have been pretty much just been riding it to work. Well today i took it on some errands and at the last stop when i tried starting it the engine was having a very hard time turning over. After a couple of tries it did start and ran fine. The battery was new this past spring so I think it is fine. Do i have a weak starter? Why only when the engine is hot?
Thanks for any help!
Tom
Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- FastKaw1
18 Oct 2008 14:30 #242462
by FastKaw1
Replied by FastKaw1 on topic Engine turns over hard when hot, any ideas?
Need more info. What you riding?
I would check all your wire connections, and timing.
XENU
XENU
- SLEEPER650
- Thank you received: 2
18 Oct 2008 18:14 #242483
by SLEEPER650
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
Replied by SLEEPER650 on topic Engine turns over hard when hot, any ideas?
sounds like you have too much advance in the timing. check your timing and make sure your advancer is working springs not broke or stuck.
78 650sr my baby
82 kz1100
- timebomb33
- Thank you received: 10
18 Oct 2008 18:23 #242484
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Engine turns over hard when hot, any ideas?
check the levels in your battery over time wet cell batterys will lose fluid due to evaporation and older kawi charging systems have been known to to overcharge a bit any time you have an problem like this always verify the battery is up to proper voltage before looking for other problems.
- Thank you received: 2098
18 Oct 2008 18:47 - 18 Oct 2008 18:48 #242493
by Patton
Replied by Patton on topic Engine turns over hard when hot, any ideas?
And if not already done, would also measure specific gravity (little floating balls test) and load test the battery.
Good Luck!
Good Luck!
Last edit: 18 Oct 2008 18:48 by Patton.
- steell
18 Oct 2008 20:09 #242512
by steell
Replied by steell on topic Engine turns over hard when hot, any ideas?
If these were real short trips, and if you spent the entire time in stop and go city traffic, then it's possible the bike got hot enough to cause the pistons to drag on the cylinder walls.
I'd check everything else first though.
- H2RICK
- Is this a fun bike, or what!!!
19 Oct 2008 11:06 #242635
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Engine turns over hard when hot, any ideas?
You MAY have a starter that's reaching the end of its life cycle. If everything else checks out okay (including the solenoid) and there's no corrosion on either end of the big wire from the solenoid to the starter itself then I'd pull the starter and disassemble it to check the brushes and the commutator. They WILL wear out eventually.....
- harm
- Tom
19 Oct 2008 18:09 - 19 Oct 2008 18:10 #242719
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic Engine turns over hard when hot, any ideas?
Thanks for the replies!
I took the battery out and checked the fluid level, they all look good. I put the battery on the charger for a little while and cleaned the connections real good. I will see how it goes this week.
When i get some more time i will check the timing and advancer.
Tom
Tom
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Last edit: 19 Oct 2008 18:10 by harm.
19 Oct 2008 18:40 #242726
by Patton
harm wrote:
This would include the connection where the negative battery cable attaches to the engine or frame.
Good Luck!
... cleaned the connections real good....
Good Luck!
