APE - Adj Cam Sprockets installation on kz900???
  • Old Man Rock
  • Topic Author
18 Oct 2008 06:40 - 18 Oct 2008 06:45 #242396 by Old Man Rock
Hey all,
While packaging my new CAM's and sprockets for shipment to Larry C., I noticed the new adjustable CAM sprockets don't have alignment scribing on them but DOT's on them instead.
The intake DOT matches the 28 pin (tooth marking) but the exhaust DOT sits at 12:00 whereas the OEM have lines to match to the head horizontal axis.
Most probably a question for APE Jay but does anyone have the alignment/installation instructions for a KZ900?
NOTE: I can get it close by comparing to the OEM sprockets but just curious on the fine tuning aspects regarding the "Adjustable" slotted sprockets.
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 18 Oct 2008 06:45 by Old Man Rock.
  • Old Man Rock
  • Topic Author
18 Oct 2008 06:54 - 18 Oct 2008 06:55 #242398 by Old Man Rock
Replied by Old Man Rock on topic APE - Adj Cam Sprockets installation on kz900??
Never mind this part of my posting, got out the trusty Ole Kawi Shop Manual and answered my own question...DOH! :whistle:
See, never too old to learn something new everyday....
OMR ponders.... Did I change my shorts today? :S
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Oct 2008 06:55 by Old Man Rock.
18 Oct 2008 10:16 #242425 by PLUMMEN
its adjustable,now i just need to find a picture of fancy gadget you mount up top to finish the process B)
18 Oct 2008 22:35 #242531 by timebomb33
Replied by timebomb33 on topic APE - Adj Cam Sprockets installation on kz900??
omr go to any of the good cam companies web sites and they will have instructions on how to degree cams properly it will realy help. what cams are you putting in the old girl.
I THINK MY POWERBAND BROKE
18 Oct 2008 22:38 #242535 by timebomb33
plumman i think the fancy gadget your refering to is a dial indicator by the way just thought i'd refresh your memory.by the way they are not gadget s they are actally refered to as thingies i'll have you know. your welcome
18 Oct 2008 22:52 - 18 Oct 2008 23:06 #242545 by PLUMMEN
thats why youre a mech- i -kneck and im just a plum-mer!:laugh: i think ol kaw man actually sells a video on degreeing cams,Larry C can point you in the right direction!B)
Last edit: 18 Oct 2008 23:06 by PLUMMEN.
18 Oct 2008 22:58 #242548 by timebomb33
i just noticed that your turbo wheels are turning again what changed, your problems over.
18 Oct 2008 23:05 #242550 by PLUMMEN
moving my shop to new part of my building where i can mock up my bike 10' from my desk,hell of a motivator!:laugh:
  • Old Man Rock
  • Topic Author
19 Oct 2008 07:51 #242598 by Old Man Rock
Cams I purchased based on what I was looking for in power and in my riding style in discussions with Bud @ Dynoman, Jeff @ Z1 and of course Larry C @ Cavanaugh racing.
Larry is doing the valve job and CAM sprocket settings so I'm not worried about it at all, just curious for installing the sprockets are not a big deal and will be real close in comparing to the OEM alignments. Just wanted to educate my mind and expand my knowledge.
I was just more interested in reading or hearing from others on the fine tuning/alignment with the adjustable sprockets aspect of it.
APE has instructions for other non KZ bikes... I'll keep searching.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
19 Oct 2008 08:42 #242610 by APE Jay
We do not include instructions on degreeing cams with any of our sprockets. Certain models like Hayabusas require an adaptor to be pressed on before sprocket installation. Those we supply instructions as to how to install the adaptors in the proper index.
Jay
  • larrycavan
  • Visitor
20 Oct 2008 18:37 #242906 by larrycavan
Replied by larrycavan on topic APE - Adj Cam Sprockets installation on kz900???
Buy a degree wheel, positive stop & at least 1" travel dial indicator, can of brake clean, tube of red locktite.
Read this article
www.muzzys.com/articles/lobe_centers.html
The trickiest part is getting the dial indicator tip to not drag on the cam, not touch the lifter bore and repeat readings. I have one I ground down very thin that works perfectly.
The math is easy. Here's a shortcut example to get lobe center.
IO 25 BTDC
IC 53 ABDC
(53 - 25) + 180 / 2 = 104
Same method for exhaust cam.
Do the cams when you can work undisturbed. Take your time. It's not difficult.
It goes much easier if you assemble only 2 valves in the head with light springs. Get some at the hardware store. Bolt the head on, torque it, install the cams in the middle of the sprocket travel holes. When you're all dialed in, remove the head and then install your normal valve springs, then assemble the rest of the motor.
20 Oct 2008 19:00 #242909 by timebomb33
Replied by timebomb33 on topic APE - Adj Cam Sprockets installation on kz900???
don't ever forget the RED LOCTITE please learn from my expensive frustrating mistake.
