Clutch plate issue
- 28years
- Live to ride
17 Oct 2008 22:51 #242368
by 28years
KZ 650 B2 1978/KZ 1979 B4
Clutch plate issue was created by 28years
I have a KZ650B--1978. The other night when it was cold out (40 degrees), the engine was running or warming up for a good amount of time, but the bike would not go forward. I let it run and warm up for another long period of time and it would not go forward in first gear--so I let it warm up for another five minutes. Finally, the bike would let me go. After running on the interstate for twenty minutes, I came to several stop signs and the bike would let me go without a hitch each time. Is there a problem with the clutch plates? Yes, in Wisconsin it does get cold already in October.
- timebomb33
- Thank you received: 10
17 Oct 2008 23:05 #242369
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Clutch plate issue
what kind and weight of oil are you using.
- Thank you received: 2098
18 Oct 2008 04:38 #242381
by Patton
Replied by Patton on topic Clutch plate issue
If not already done, would perform clutch push rod adjustment.
Let us know if more info about this is needed.
Good Luck!
Good Luck!
- 28years
- Live to ride
22 Oct 2008 12:07 #243243
by 28years
Replied by 28years on topic Clutch plate issue
Hello: I want to thank those that responded to my problem about clutch plate problems. I made an adjustment to the clutch plate as suggested. It worked, I'll be darned:laugh:
What's interesting is: the cable midway has an adjustment to take up the slack in the clutch cable. I thought that the clutch cable play was sufficient for this fix. :ohmy:
The problem could have been too much oil, oil not changed, oil filter not changed,...
Doug Johnson
Doug Johnson
