mk11 cam gears in a 900 head
- School Teacher
17 Oct 2008 13:02 #242281
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
mk11 cam gears in a 900 head was created by School Teacher
will they work with the 900 stock valve cover?
1980 kz1000G1
- mark1122
- Keep twisting it
- Thank you received: 109
17 Oct 2008 15:21 #242288
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic mk11 cam gears in a 900 head
NO and yes. The mk11 has 32 teeth the kz has 28. they will fit but unless u use a MK11 crank, wich has 1 extra tooth , your timing will be out.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- School Teacher
17 Oct 2008 15:23 #242289
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic mk11 cam gears in a 900 head
the 900 is the head, on a mk2 bottom. with the 32 tooth gear they are bigger do they fit under a stock valve cover?
1980 kz1000G1
- mark1122
- Keep twisting it
17 Oct 2008 17:11 #242302
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
yes. i have a mk11 crank and mk11cam gears in my kz 77block and 76kz head and a kz valve cover.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- racer54
- Thank you received: 114
17 Oct 2008 19:19 #242343
by racer54
Replied by racer54 on topic mk11 cam gears in a 900 head
Just for the record, the Z1 and KZ1000 cam gears are 30T. Mark is correct, the valve covers will interchange.
- mark1122
- Keep twisting it
17 Oct 2008 19:22 #242344
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Thanks for the correction racer.Your right as usual.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
