- Thank you received: 1
Getting stuck between the gears
- toadson
17 Oct 2008 11:29 #242270
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Getting stuck between the gears was created by toadson
I've ran into this problem every once in a while on my 79 KZ1000 LTD, but as of lately it seems to happen nearly every time I ride it. I run Rotella T 15w-40 in my bike and change the oil at least twice a year, about every 2k miles or maybe less.
It used to happen when I would go WOT and go to shift into the next gear, and the thing would get stuck between gears, acting like it is in neutral. It feels like it engages, but obviously doesn't. I have to upshift again to get it into gear. A few times I would accidentally rev it into redline since I thought I was going into the next gear, so I would like to try and find a remedy for this problem before something blows up!
Could I have bent shift forks or something? It used to happen most often between 1-2, but it seems like it will do it in any gear now. I've had it happen during regular cruising too, and its sort of embarrassing when you go to shift, and end up revving the engine instead of hitting the next gear. The bike has about 33k miles on it and I'm sure the engine and transmission are stock.
- timebomb33
- Thank you received: 10
17 Oct 2008 23:09 #242370
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Getting stuck between the gears
how does your shifter feel is it tight or does it have play in it. it almost sounds to me like the return spring on the shifter shaft has weakened.
- toadson
18 Oct 2008 00:33 #242376
by toadson
Replied by toadson on topic Getting stuck between the gears
I think it may have some play in it, but never really have paid attention. I'll check it out sometime tomorrow. How hard is it to get to that spring?
- Old Man Rock
- Thank you received: 225
18 Oct 2008 07:11 - 18 Oct 2008 07:13 #242403
by Old Man Rock
It's not a 5 minute job but it isn't over complicated either. You'll need to remove your chain cover and counter sprocket to get to the external shift mechanism.
Since you have to remove the transmission cover to get to the shift mechanism, probably smarter to replace the gasket and seals while your at it...
For OEM parts fiche files...
www.babbittsonline.com/pages/parts/viewbybrand/9/Kawasaki.aspx
Z1 enterprises has them.... $6.30 plus shipping...
www.z1enterprises.com/detail.aspx?ID=2641
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Getting stuck between the gears
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Oct 2008 07:13 by Old Man Rock.
- toadson
19 Oct 2008 01:33 #242573
by toadson
Thanks for the link, but I'm hoping I won't need it now! I checked out my shifter today, only to find that the shifter level itself was loose on the rod, causing some play. So I tightened it up, and the play is gone! Shifting from 1st to 2nd still feels a bit odd, but I didnt have it get stuck between gears today, which made me happy. I probably never would have bothered looking at it if it werent for this thread, so thanks!!!
- H2RICK
- Is this a fun bike, or what!!!
19 Oct 2008 11:02 #242633
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Getting stuck between the gears
I love low-tech solutions to high-tech problems. A loose shift lever bolt.....
I must have told a hundred guys over the years that, yes, that bolt needs to be checked EVERY time you change the oil.
They WILL loosen up over time and then you get the exact problem that toadson describes. Worst case with that bolt left loose is you will wreck the splines on the shifter shaft and/or ruin the tranny itself.
So.....tell everyone you know to perform this simple check every time they change their oil. A light tug with a box-end wrench on that pinch bolt on the shift lever. Simple stuff...
- toadson
27 Oct 2008 23:09 #244206
by toadson
Last time my cousin and I went riding, his shifter lever fell completely off his 76 Sportster. It was fun trying to find that in the dark on the backroads, but we managed to find it lol. Thanks for the tip, I'll keep an eye on it.
