- Thank you received: 5
TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
- dshelly
16 Oct 2008 10:53 #242119
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION was created by dshelly
This winter, the plan is to do a top end rebuild on my 77 KZ1000. Using Std bore Wiseco pistons and rings, also doing a valve job. So after all is said and done , should a guy baby it for the first tank of gas or ride like you intend to from the start?? What is best to seat new rings? Any thoughts ?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- BSKZ650
- Thank you received: 14
16 Oct 2008 11:30 #242122
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
first question, are you sure you will be able to use standard pistons and rings, the cyls may not be in spec and oversize may be needed.
I have always had the opinion, fire it up, set everything, timing carbs etc, retorque the head, make sure there are no leaks, and ride it, no baby stuff here
- dshelly
16 Oct 2008 12:05 #242130
by dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
Std pistons ? Yes, If not the cylinder That's on it. I have a backup that checks out good. Just needs a quick honing.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- wiredgeorge
16 Oct 2008 12:15 #242136
by wiredgeorge
Replied by wiredgeorge on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
Your bike was broken in 30 years ago. It doesn't need break-in again. The piston rings need to seat. Vary engine speeds and don't drone along at one constant speed.
- Mcdroid
- Gone Kwackers
- Thank you received: 317
16 Oct 2008 12:41 #242137
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
wiredgeorge wrote:
:laugh: :laugh: :laugh: :laugh: :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- coppertales
17 Oct 2008 11:31 #242272
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
I follow the decal on my tach. It was good enough 26 years ago and should be ok now. I picked up a set of gauges off ebay last year and the tack still had the break in decal on it. Ring seating is the most important part of a break in so I take it easy. If I want to go fast, I just ride one of the other bikes....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- ratvespa
18 Oct 2008 09:44 #242422
by ratvespa
Replied by ratvespa on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
I just did a top end on my my 1100, for the first 500 I took it easy, tried to vary my engine speed as much as possible, as I got closer to 500 I started rev'n it a bit more when I drove. when I first got it together it smoked a bit, now it does not smoke at all, so the break in I did must of work.
Ive seen the downfalls of improper break in, mostly on the harley twincam engines I put together, break them in right, no problems, and ive had customers hop on the freeway and blast home for 100 miles, only to be back at my shop 2 days later with the cyl's and pistones scored up and destroyed.
- onanysunday
18 Oct 2008 12:37 - 18 Oct 2008 12:41 #242445
by onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
Replied by onanysunday on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
If you're already going to the trouble of spending money on a top-end rebuild with Wiseco you may as well go for one of their oversized, big bore piston kits-I know I would.
79 KZ1000 E-1
VM28SS
K&N Pods
Last edit: 18 Oct 2008 12:41 by onanysunday.
- baldy110
- Thank you received: 512
19 Oct 2008 18:56 #242733
by baldy110
Replied by baldy110 on topic TO BREAK IN OR NOT TO BREAK IN THAT'S THE QUESTION
My ring seating procedure is pretty simple. I ride it like I stole or rented it, change the oil and filter after 20 minutes, let it cool down, re-torque the head bolts, then just ride it.
