Starter Clutch, How do I get it out??
- Aaronandhiskz550
16 Oct 2008 07:41 #242088
by Aaronandhiskz550
1981 KZ 550
Starter Clutch, How do I get it out?? was created by Aaronandhiskz550
I have a 1981 KZ 550 that I have been restoring. I finally get it running on 3 out of 4 cylinders and now the starter clutch goes. The starter motor is still good, and I have pulled both engine side covers off, the clutch and oil pan. So now I'm trying to see what is wrong. How do I get the starter clutch shaft out? Is the engine going to have to be split? Am I missing something? HELP!! It's starting to get cold and I want to ride.....
1981 KZ 550
- mariozappa
- Thank you received: 8
16 Oct 2008 08:02 #242092
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Starter Clutch, How do I get it out??
This should be very similar to what you will have to do.
kzrider.com/index.php?option=com_docman&...d&gid=389&Itemid=108
1977 KZ650C1
- Aaronandhiskz550
16 Oct 2008 18:23 #242172
by Aaronandhiskz550
1981 KZ 550
Replied by Aaronandhiskz550 on topic Starter Clutch, How do I get it out??
Thanks! This looks pretty good. Hopefully I'll be back to riding soon.
1981 KZ 550
- hugo
- '92 Zephyr 750
- Thank you received: 70
17 Oct 2008 05:25 #242236
by hugo
Replied by hugo on topic Starter Clutch, How do I get it out??
Yes,all of the above, and you can do it with the engine in the frame. I have done it.
- ThatGPzGuy
- Thank you received: 385
17 Oct 2008 16:40 #242294
by ThatGPzGuy
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Replied by ThatGPzGuy on topic Starter Clutch, How do I get it out??
You can do it with the engine in the frame but if you are farsighted like me you may want to yank the engine out of the frame. You won't have to lay on your back and it's way easier to do the starter clutch and scrape gaskets. Plus it gives you the opportunity to clean up the frame area.
Good luck,
Jim
Good luck,
Jim
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Aaronandhiskz550
18 Oct 2008 13:16 #242455
by Aaronandhiskz550
1981 KZ 550
Thanks to all for the advice. I was able to get the starter clutch out and found that the little pins and springs inside it had disintegrated to little spring pieces. New springs have been ordered because everything else still looks good. Next is to put my KZ Humpty Dumpty back together again. Thanks again and happy riding.
1981 KZ 550
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
19 Oct 2008 11:11 #242636
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Starter Clutch, How do I get it out??
Aaron, I'd also replace the rollers as well as the pins and springs, just on general principles. I believe that you can get all the bits as a complete kit from most of the aftermarket guys like Z1E, etc.
