- Thank you received: 1
wastegate needed with blow through?
- martijn
13 Oct 2008 04:53 #241539
by martijn
wastegate needed with blow through? was created by martijn
Do I need a wastegate between head and turbo when using a blow- trough application??
- BSKZ650
- Thank you received: 14
13 Oct 2008 05:35 #241543
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic wastegate needed with blow through?
I am not sure what a blow thru is, everytme I have seen a turbo it has a waste gate of some type
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
13 Oct 2008 06:49 #241549
by tachrev
Build Thread
Replied by tachrev on topic wastegate needed with blow through?
You always need a wastegate unless you want the turbo to try to run as much boost as it possible can all the time.
Most engines and turbo can't handle that. A turbo can and will run out of its efficiency range(making lots of heat) if you let it.
However, you may need a blow-off valve in a blow-through setup, where you wouldn't need it in a draw-through setup.
Build Thread
- JAILBAIT
13 Oct 2008 12:51 #241613
by JAILBAIT
Replied by JAILBAIT on topic wastegate needed with blow through?
- PLUMMEN
- Thank you received: 104
13 Oct 2008 17:42 #241653
by PLUMMEN
Replied by PLUMMEN on topic wastegate needed with blow through?
JAILBAIT wrote:
In a blow-through situation the setup is like this...
Wastegate on exhaust side
Blowoff Valve on pressure side
- martijn
14 Oct 2008 01:47 #241722
by martijn
Replied by martijn on topic wastegate needed with blow through?
Thank you all!!
So If I should make a blow trough turbo I do need a gasfeul pump to overwin the turbo pressure and the bowl also has to be pressurized??
When using a carb in front of the turbo inlet I do not have to do all this? only taking care of not overspinning the turbo (and pressure) by using an exhaust blow off just like Jailbait's picture?
second question: how do you turbo riders lubricate the turbo?? since a KZ has not such a high pressure and flow.
Would you recommend an electrical oilpump like mocal??
- PLUMMEN
14 Oct 2008 04:57 #241726
by PLUMMEN
im going to run a seperate pump,possibly a complete seperate system for mine to maintain pressure to turbo bearings before and after shutoff since they continue to spin after after engine is turned off.
- zippy
14 Oct 2008 11:25 #241786
by zippy
Replied by zippy on topic wastegate needed with blow through?
martijn wrote:
Go to here and call them. This is all ya need to know (and then some)
www.turbosystem.com/cycle/index.htm
