Sounds like rod knock , but not....
- lx460
11 Oct 2008 03:02 #241221
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Sounds like rod knock , but not.... was created by lx460
So I picked up a kz100 that's been sitting for awhile. (sound familiar so far) Cleaned the carbs , checked cylinder compression, changed oil, put in new battery, fired it up. First thing I notice is a sound like a rod knocking. Listen closer, , maybe not. Pull in the clutch and it goes away. Good sign I think? Any ideas what I should be looking for when I pull it apart? Is it something that will jump out at me or something less obvious like worn springs? It's coming apart anyways but any ideas are appreciated. Thanks.
BTW, I took it for a test ride down the street. It shifts fine and rides fine with no slipping either. It just sounds horrible at idle.
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- saltydog
11 Oct 2008 04:32 #241222
by saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
Replied by saltydog on topic Sounds like rod knock , but not....
Is it idling too slow? If so, it could be gear backlash. Run the idle up a little.
- mark1122
- Keep twisting it
- Thank you received: 109
11 Oct 2008 04:42 #241224
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Sounds like rod knock , but not....
is this noise just at idle ,when u pull in the cltch, or while riding as well when u pull in the clutch?
i have seen the clutch basket spings go,1st hand. mine did not make any noise. i just happened to find a piece of spring in the oil pan when i did a rebuild.
I can see how it could make a noise like a rod though.
As the springs wear they can push the metal around them outwards.Or the springs themselves.if it goes out enough it could rub on the blocks suport ridges as they pass.
u cant see this without spliting the cases.
You might be want to check for metal in the oil pan and behind the clutch cover. Just as a precausion.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- zombiescustoms
11 Oct 2008 06:04 #241228
by zombiescustoms
Replied by zombiescustoms on topic Sounds like rod knock , but not....
Mine had some broken clutch discs, one was cracked and another had a peice missing, it made a terrible racket but would change sound when the clutch was disengaged.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 Oct 2008 07:22 #241238
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Sounds like rod knock , but not....
Hey lx460...
If you havnt already, check the camchain tensioner. The Pilot mixture screws. Manometer vacuum sync the carbs (or have it done for you).
The one thing that has happened to me, on more than one occasion that sounds kinda like a knock, is the stupid starter clutch bolts. Twice I've had to dissasemble the starter clutch and torque/threadlock the clutch assembly bolts. (They're down good now!)
Trust me , when those bolts are backing out it makes the engine sound HORRIBLE at idle, bet then as soon as you cruise along (over 2500rpm) seems to dissapear.
I "think" your clutch may be dragging slightly, causing a drop in rpm with it out. Mine did this after sitting for a LONG TIME... Adjust at the cover, accordingly.
Once all that stuff is done proerly, these engines start to sound pretty good. You can just search the forum for "how-to" info for the above mentioned.
Cheers!, and good luck...
...patience!
...patience!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
11 Oct 2008 09:44 #241258
by PLUMMEN
Replied by PLUMMEN on topic Sounds like rod knock , but not....
sync your carbs,adjust timing chain and tune it up if you havent already
- Thank you received: 2827
11 Oct 2008 10:05 #241261
by Nessism
Replied by Nessism on topic Sounds like rod knock , but not....
Clutch noise at idle is normal; the friction plates have tabs on them that engage with matching slots on the clutch basket. The plates have relative motion against the clutch basket which creates noise.
If the clutch plates/basket is worn, the noise gets worse. Barnett clutch kits, the type that have thin plates, tend to gouge out the basket and create lots of noise.
Other possible problems include broken basket springs and as others have mentioned, broken plates and such (quite rare).
Best to pull down the clutch and have a look see. Look closely at the basket for any notching.
Good luck.
Good luck.
- School Teacher
12 Oct 2008 02:27 #241394
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic Sounds like rod knock , but not....
i have the same thing going on. havent figured it out yet.
1980 kz1000G1
- trippivot
- Thank you received: 3
12 Oct 2008 10:07 #241433
by trippivot
Replied by trippivot on topic Sounds like rod knock , but not....
that is a normal noise guys!!
if the engine is out of tune it is louder
you can synchronize and idle drop all 4 carbs then turn the idle up a bit but that is normal.
holding in the clutch quiets the lash from the crank to basket
it is the straight cut gear lash. straight gears make noise and do not side load. unlike the GS 1000 gs1100 they have a side cut gear that is very quiet but creates side thrust in hi-performance engines.
- School Teacher
12 Oct 2008 21:34 #241524
by School Teacher
1980 kz1000G1
well mine is a little more and seems to go away when warm.
i have two other kz's and what im hearing ain't acceptable as normal
1980 kz1000G1
- PLUMMEN
13 Oct 2008 02:24 #241534
by PLUMMEN
they tend to do it more when cold then should go away as the motor warms and smoothes it self out.
