- Thank you received: 5
compressoin ratios, power, fuel?
- jordan
10 Oct 2008 09:34 #241110
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
compressoin ratios, power, fuel? was created by jordan
I am debating on the compression ratio for my 1327 kz1000 project. It will probably be street riden more than it will hit the strip, although i am hoping for impressive numbers when i do make it there. If i settled for the 10.5:1 compression pistons over the 12.5:1 pistons would there be considerably less power? Also, I know it has been discussed before but what octane fuel is required for both ratios. ALso, If I got some massive fuel lines and did the required work, would E85 be a possible solution for the higher octane fuel since it is easily accessible at the pumps?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- Thank you received: 104
10 Oct 2008 12:46 #241137
by PLUMMEN
Replied by PLUMMEN on topic compressoin ratios, power, fuel?
might as well get some alcohal versions of these!
:laugh: id check around and see if you can get something more in the area of 9.5:1 youve got plenty of cc's there no need to run a truckload of compression on a streetbike!check your pm i might have the answer you need sitting in a box somplace around here! :evil::laugh:
- mark1122
- Keep twisting it
- Thank you received: 109
10 Oct 2008 14:43 - 11 Oct 2008 04:57 #241148
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic compressoin ratios, power, fuel?
10.5:1 seems to be the upper limit for pump gas. guys are having to make timing adjustments to make it work.
if u want to get better times at the track u would be better off focusing on traction(clutch,shifter, tires), than more compression.
Remember that u are going to be fighting heat on the street, and more comp. = more heat.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 11 Oct 2008 04:57 by mark1122.
- timebomb33
10 Oct 2008 22:12 #241209
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic compressoin ratios, power, fuel?
YOU SHOULD BE ABLE TO GET AWAY 10.5-1 COMPRESSION WITH OUT TOO MUCH PROBLEM I WOULD LOOK AT GOING TO A BIT BIGGER CARB PERHAPS 38 FLATSLIDES OR EVEN 40'S. 34'S ARE A BIT SMALL FOR THAT BIG OF AN ENGINE . I WOULD BE LOOKING AT AN OIL COOLER SINCE THERE ARE NO AIR PASSAGES IN THAT BIG BLOCK OF YOURS ALSO MAKE SURE YOUR IGNITION IS IN TIP-TOP SHAPE. AN IGNITION MODULE THAT HAS AN ADJUSTABLE TIMING RETARD FEATURE WOULD BE NICE SO YOUR NOT HAVING READJUST YOUR TIMING PHYISICALLY ALL THE TIME.THOSE SMALL CARBS WOULD GIVE YOU EXCELLENT THROTTLE RESPONSE BUT YOUR TOP END WILL RUN OUT OF AIR REALLY QUICK. SOUNDS LIKE ITS GOING TO BE A FUN BIKE. WHERE IN ONTARIO ARE YOU FROM BECAUSE I RACED IN ST. THOMAS THIS MAY.
- mark1122
- Keep twisting it
11 Oct 2008 05:03 - 11 Oct 2008 05:07 #241226
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
I run a Dyna 2000 . It has a timing curve that has less timing at mid rpm's. this helps with higher compression.It also replaces that worn out mechanical advancer with an electronic unit.U can even write your own curves.(i dont know how to ,myself though)
timebomb33 :
I run the rs34's firstly because thats what i had.but also my head has been ported for this size,so it does not fall off at the top.
I live in Cobourg Ont. 1hr east of TO.
I'd love to check out the drags some time,in St. T.
Email me next time u are going.
There are lots of guys here we could round up for a get together.
timebomb33 :
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 11 Oct 2008 05:07 by mark1122.
