Oil dripping out of airbox-- normal ? kz1000-P-19
- zshark
10 Oct 2008 08:33 #241096
by zshark
Oil dripping out of airbox-- normal ? kz1000-P-19 was created by zshark
:dry: :huh: I have had the bike for only 6-months. I have not worked on motorcycles before, but have worked on cars. Plugs do not show any oil getting pass the rings. Any suggestions on the steps to take to make sure that the engine is ok? Thanks
- mariozappa
- Thank you received: 8
10 Oct 2008 09:59 #241117
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Oil dripping out of airbox-- normal ? kz1000-P-19
My first thought would be too much oil in the crankcase.
1977 KZ650C1
- Thank you received: 2098
10 Oct 2008 13:54 #241139
by Patton
Replied by Patton on topic Oil dripping out of airbox-- normal ? kz1000-P-19
Might also be excessive blow-by past compression rings into crankcase. Could perform compression test, or better yet, a leak down test.
Good Luck!
Good Luck!
10 Oct 2008 14:07 #241140
by Patton
And WELCOME to KZR forum, zshark!
We're glad you're here!
If doing a compression test, remember to hold the throttle wide open while spinning the engine over.
If low compression, add a teaspoon of oil into cylinder and re-test (checks compression rings). If still low after oil added inside cylinder, check and adjust valve clearances to specs (too tight valves are often the cause of poor compression on these bikes).
Good Luck!
Good Luck!
- mark1122
- Keep twisting it
- Thank you received: 109
10 Oct 2008 14:37 #241147
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Oil dripping out of airbox-- normal ? kz1000-P-19
Well-said guys. Booth of these things could cause oil to appear in the air box. Blow buy is common.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
