Bike nosing over at 5600-6000 RPM
- 83GPZ
09 Oct 2008 22:26 #241047
by 83GPZ
Bike nosing over at 5600-6000 RPM was created by 83GPZ
What I have is an fuel injected 83 gpz 1100, the air box has been replaced by a set on k&n pods(No ATS on bike). The bike is losing power around 5600-6000 rpm. It seems like it could be the clutch because the rpm shoot up even though the bike is dropping the nose.
1. Would the bike not having a Air Temp Sensor on it cause it to do that?
2. Would a clutch that is slipping cause this?
3. Could this be caused by a lack of fuel? What fuel pump and adjustable fuel pressure regulator could I replace my stock stuff with?
Thanks In Advance,
Tee
Thanks In Advance,
Tee
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
10 Oct 2008 05:17 #241078
by tachrev
Build Thread
Replied by tachrev on topic Bike nosing over at 5600-6000 RPM
If the bike stops accelerating, but the RPMs keep increasing, then it definitely sounds like the clutch.
What you described it usually a pretty good indicator.
Build Thread
- BSKZ650
- Thank you received: 14
10 Oct 2008 05:36 #241084
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Bike nosing over at 5600-6000 RPM
if you put in 5th gear at a low speed and nail the gas,,, rpms come up and bike dosent take off,, clutch
