- Thank you received: 7
How to: Valve-stem carbon removal?
- riverroad
- 1980 1000LTD B4
But I've also heard that transmission fluid will do it too, but I wouldn't recommend it on a motorcycle engine. I'd be worried about scoring the cylinder walls.
But since you can actually look in your exhaust ports and see the valves, I don't see where it would hurt anything to paint some tranny fluid directly on the carbon deposits. Maybe it'll soften it up and blow out next time you run it.
- PLUMMEN
- Thank you received: 104
- OnkelB
- Thank you received: 80
But since you can actually look in your exhaust ports and see the valves...
Just don't run the engine with the headers off...
77 KZ 650 B1, 82 GPz 1100 B2.
- PLUMMEN
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
- PLUMMEN
- Mcdroid
- Gone Kwackers
- Thank you received: 317
hold your hand back a couple feet from exhuast,youll feel the little chunkshitting your hand!:laugh:
All right...what the hell is chunkshitting!?!?!?! Never mind, I really don't want to know...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- PLUMMEN
chunks hitting!:laugh: i type with one finger and you expect me to be able to spell also?:woohoo:PLUMMEN wrote:
- wiredgeorge
I doubt water will clean the carbon off valves where it is baked on and thick. One of the gas station companies sells gas with a chemical called Techron which is made to remove this stuff. You can buy bottles of the stuff to use in higher concentration but I doubt it will remove burned on carbon. I think a wire brush wheel on a drill or Dremel tool would be the best bet. If the stuff has crept up high enough, the stem seals will be toast. I would buy a new cylinder head gasket and remove the head and do some cleaning and have some new seals on hand.
- onanysunday
79 KZ1000 E-1
VM28SS
K&N Pods
- bigkzfan
- if grandpa had tits he"d be grandma, if
well.i work at car x and we do induction services in the upper intakes and i have seen first hand that there products just melts away built up carbon may take a few times but it will do it
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
