Why do I need an aftermarket exhaust?
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- steell
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- bountyhunter
- Thank you received: 337
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- bemoore
- Thank you received: 4
77 KZ650C1 w/Kerker 4-1
- 77_650B1
PS - I am an engineer, I'm well capable of tuning an exhaust for power. The only reason I'll buy an afetrmarket is because I'm lazy and dont wanna spend multiple hours crunching numbers and combing through my engine books. And you're right, it'll be easier to get tuning advice on an aftermarket.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- BeeSting
- Drive it like your tax dollars already paid for it
There are people in this world that probably worry over the value of a piece of feces that they uncovered at an archeological dig, but in the real world (one where people aren't pouring out tens of thousands for a custom KZ or a piece of manure) it makes more sense to think about the fun/pride/something to do value that the owner places on the bike.
Doing some tinkering with an exhaust system during the winter months sounds like a cool idea. If you could baseline your current setup and check your progress along the way, you might be able to come up with some low-buck solutions for those of us that don't have $400 to spend on a new system. And as far as 50 lbs weight savings? Thats silly - the stock systems dont weight that much.
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
- steell
Ever weighed a 650/750 stock exhaust?
I haven't, but here's some anecdotal evidence to consider.
Stock 750 twin exhaust, I have to block it up in place to bolt the header flange up, because it's so heavy. 650/750 four into one I can hold in one hand while attaching the header flange nuts with the other.
Never weighed a stock KZ with stock exhaust, but have weighed the 650 and 750 fours with aftermarket four into one exhaust wet (Oil, battery, and full of fuel), and they end up weighing less than the published dry weight.
50 lbs is a swag, but it wouldn't surprise me if it was really close to that.
- Makarth
- Thank you received: 1
- BeeSting
BeeSting
Christine
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
