Lobe centers KZ1200
- martijn
Lobe centers KZ1200
15 Feb 2006 12:45
Hello,
I do need some advice at stting the lobe centers using web .395 cams. They will be running on top of of 1200cc bigger bore.
Does someone has some experience doing so??
thanks
martijn:woohoo:
thanks
martijn:woohoo:
- MDawnz1
- Duck
- e vica na i sau na ga
Re: Lobe centers KZ1200
17 Feb 2006 16:34
martijn
Are you asking where to put the centers or how to locate the centers so you can put them where you want?
-Duck
-Duck
- martijn
21 Feb 2006 01:47
Where to put the lobe centers, their distance. I know how to measure en find the centres. I've heard that a few degrees more or less can have a major change on engine behavoir (especially intake cam).
thank you
Martijn
thank you
Martijn
- Duck
21 Feb 2006 05:00
Martijn-
I can't help with where to set them. Haven't studies cams yet.
You might try asking on dragbike.com forums.
-Duck
-Duck
