Idle varies a lot between cold and hot 1978 KZ1000
- Richard XYZZY
06 Oct 2008 16:30 #240438
by Richard XYZZY
Idle varies a lot between cold and hot 1978 KZ1000 was created by Richard XYZZY
The idle level changes drastically on my KZ from when its started cold to when it heats up.
When its hot I have to spin up the idle dial so that the bike doesn't stall when I let off the throttle.
When its cold, still having the idle level set from when the bike was hot, I have to spin that idle dial quite a bit to get it from around 5000RPM to around 2000RPM.
If I set the idle to anything lower than about 2000RPM (whether hot or cold) the bike tends to stall unless I hit the throttle when the clutch is out.
- Thank you received: 2098
06 Oct 2008 17:53 #240452
by Patton
Replied by Patton on topic Idle varies a lot between cold and hot 1978 KZ1000
Possibly the advancer is sticking. Using a strobe-type timing light, should be able to watch it move back and forth as rpm are varied.
Good Luck!
Good Luck!
- bill_wilcox100
- Thank you received: 5
06 Oct 2008 18:16 #240456
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Idle varies a lot between cold and hot 1978 KZ1000
Just a thought here... are your rubber carb holders, between the carbs and the block, leaking?
Best of success.
Best of success.
Upgrades:
Montreal, Canada
06 Oct 2008 18:39 #240464
by Patton
bill_wilcox100 wrote:
If needed, new carb holders are listed at Z1E
carb holders
And another possible source of air leak
vacuum caps
Good Luck!
... are your rubber carb holders, between the carbs and the block, leaking?....
carb holders
vacuum caps
Good Luck!
06 Oct 2008 18:43 - 06 Oct 2008 18:46 #240465
by Patton
If not already done, would check valve clearances and assure being set to factory specs.
Might be too tight, so as to be sealing when cool, but begin leaking at normal operating temp.
Just thoughts.
Just thoughts.
Last edit: 06 Oct 2008 18:46 by Patton.
- timebomb33
- Thank you received: 10
06 Oct 2008 18:59 #240470
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Idle varies a lot between cold and hot 1978 KZ1000
sounds like a bad air leak spray some carb or brake cleaner around the intake manifolds, if the engine chages in r.p.m you have just found your leak
- trippivot
- Thank you received: 3
07 Oct 2008 06:23 #240564
by trippivot
Replied by trippivot on topic Idle varies a lot between cold and hot 1978 KZ1
you have described the exact opposite of normal.
after any carburetor/airbox modification from totally stock a motorcycle will usually need the rider to turn the idle UP when it is cold to keep it running smooth and as it heats up the idle needs to be turned back DOWN to a lower idle speed.
as the engine builds heat the efficiency level goes up and therefore needing LESS gas/air mixture to run when at full operating temperature.
so your description leaves many unanswered questions because it does not add up.
start at the beginning
leak down test.
compression test
new spark plugs
reset the points
reset timing
lube the advancer
re set float heights
synchronize carbs at idle AND 2000 R.P.M.
lean idle drop all 4 carbs
check for loose bolts and tight spots on the carb bank dealing with the throttle cable, slide lift pivot, assure all slides fully seat when closed.
and by the way- fire the mechanic that got you to this point.
leak down test.
compression test
new spark plugs
reset the points
reset timing
lube the advancer
- trippivot
07 Oct 2008 06:24 - 07 Oct 2008 06:26 #240565
by trippivot
timebomb33 wrote:
not even a close guess with this description he has given
Last edit: 07 Oct 2008 06:26 by trippivot.
