- Thank you received: 5
Why is there a hole in the #1 piston?
- Gman
04 Oct 2008 13:13 #240132
by Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
Why is there a hole in the #1 piston? was created by Gman
I have a '75 Z1 motor from a parts bike that I planned to re-ring and use in a project bike. When I pulled the cylinder I found the #1 piston has a hole machined in the side and a corresponding hole in the #1 sleeve. None of the other pistons or sleeves have this hole. Can anyone tell me the purpose of these holes and whether it ok to re-use these parts? Thanks.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- Gman
04 Oct 2008 13:14 #240134
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Replied by Gman on topic Why is there a hole in the #1 piston?
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- MFolks
- Thank you received: 540
04 Oct 2008 13:28 #240137
by MFolks
Replied by MFolks on topic Why is there a hole in the #1 piston?
Possibly the engine came this way from the factory due to a machining error or an oil control problem. I'd ask at the engine rebuilders as I'd never seen that before.
1. www.aperaceparts.com
2. www.redlinecycle.com
3. www.dynoman.com
4. www.kzzone.com
5. www.fastbygast.com
6. www.partsnmore.com
If the above do not have the answer I do not know where else to look.
3. www.dynoman.com
4. www.kzzone.com
- mark1122
- Keep twisting it
- Thank you received: 109
04 Oct 2008 14:41 #240144
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Why is there a hole in the #1 piston?
I dont have an answer for you. Sorry . Just more questions.
That is a new one for me.
Is the hole in the sleeve below the block ?
Do the rings go down as far as the hole in the sleeve while running?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Gman
04 Oct 2008 16:34 #240154
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Sorry to bother everyone, I feel like an idiot. After I looked at it closer with my glasses on I see that it goes all the way through the block. Like someone sabotaged the motor by drilling a hole through it from the outside. Pretty much ruined that set of block and pistons. Makes me wonder what else may have been done to the engine. It was on a parts bike I bought as is. So it goes.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- KZQ
- Administrator
- Thank you received: 1415
04 Oct 2008 17:57 #240166
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Why is there a hole in the #1 piston?
All the way through? Seems like it would have had to go through the connecting rod as well.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- PLUMMEN
- Thank you received: 104
04 Oct 2008 19:01 #240177
by PLUMMEN
Replied by PLUMMEN on topic Why is there a hole in the #1 piston?
how big is the hole?drop another sleeve and piston in the block and carry on
- Gman
05 Oct 2008 04:48 #240211
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Here's a pic of the offending hole from the outside. Plummen, I'm sure it can be fixed with a new sleeve and piston if I want to go that route. Complete stock 903 jugs and pistons can be had pretty reasonable so I don't it it's worth messing with. I have a 1015 10.25:1 kit I can drop on it so no big deal. I was just leaning towards a motor that runs on reg gas.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- PLUMMEN
05 Oct 2008 08:21 #240234
by PLUMMEN
check your pm
- fixer5000
05 Oct 2008 09:14 #240242
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Why is there a hole in the #1 piston?
wow i think thats a first
massachusetts
- mark1122
- Keep twisting it
05 Oct 2008 11:41 #240252
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
You can run 10>25:1 pistons on premium pump gas.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 2 stroker
05 Oct 2008 11:51 #240256
by 2 stroker
1965 suzuki s32 150 twin
1972 yamaha ls2 100 twin
1980 suzuki gs 550 rat cafe project
1981 kawi 550A1 hooligan bike project
1981 kawi kz 750 ltd
1998 yamaha yzinger
Replied by 2 stroker on topic Why is there a hole in the #1 piston?
some ass probably wanted the make sure it stayed a parts bike
1998 yamaha yzinger
