Kerker rear peg mounting Brackett?
- Oldwolf
03 Oct 2008 18:06 #240027
by Oldwolf
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
Kerker rear peg mounting Brackett? was created by Oldwolf
Looking for a pic of how a kerker Megaphone mounts to the rear Peg area on a 1977 KZ1000 A1. And can the Rear foot rest still be folded? Would like to see a close up of how this has been done. I looked thru the Gallery and could not find that many A1's with Kerkers. Thanks for the Help.
- Thank you received: 2098
03 Oct 2008 18:53 - 03 Oct 2008 18:55 #240037
by Patton
Replied by Patton on topic Kerker rear peg mounting Brackett?
KZ900-B1 LTD with Kerker attached using a simple fabricated bracket and a little rubber "motor mount" which isolates the frame from vibration.
No adverse effect at all on normal operation of folding right rear passenger peg. Foot peg is flipped up in the photo.
Good Luck!
[Click on image to enlarge view]
Good Luck!
Last edit: 03 Oct 2008 18:55 by Patton.
- PLUMMEN
- Thank you received: 104
03 Oct 2008 19:40 #240048
by PLUMMEN
Replied by PLUMMEN on topic Kerker rear peg mounting Brackett?
i dont have any close ups but the a1-a2 use a stamped steel footpeg bracket differant tha the tubing used on b model bikes.there is actually a tab with a hole under the footpeg bracket for the exhuast mount if it hasnt been removed same basic idea you just bend a piece of plate to fill between the header and frame mount.
- gane
03 Oct 2008 20:08 #240051
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Kerker rear peg mounting Brackett?
Oldwolf, My Kerker meg's mount was aft of the rider peg by @ 2". by fabing a double 90 degree (straight Z) bracket of heavy aluminum strap.(@1'x1/4) I was able to mount from the inboard side of peg mount retaining the stock rubber damper/peg locator, and securely mount to meg, providing a solid,nearly invisible yet still rubber mounted hanger without any interferance w/passenger peg. '77 kz1000. G
- Gman
- Thank you received: 5
04 Oct 2008 05:43 #240084
by Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
Replied by Gman on topic Kerker rear peg mounting Brackett?
Here's a pic of my '78 A2. I beleive the frame is same as yours. It has a short bracket that came with the pipe when I bought it years ago.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- Gman
04 Oct 2008 05:45 #240086
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
