Broken Fins
- jwm1120
03 Oct 2008 05:07 #239914
by jwm1120
Broken Fins was created by jwm1120
I have some broken fins on my 77 KZ 650. Not many, only two or three and the don’t go all the way into the block, only the outer edges. Besides it looking bad, are there any issues that would pop up because of this? Could they be the beginning of stress fractures?
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
03 Oct 2008 07:19 #239935
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Broken Fins
Pics of damaged/broken fins ???
Usually if it's just the outer part of the fin there will be no probs. If any are broken off at the root right up against the block well, that's another story entirely.
Also the cause and mechanism of the breakage will tell a story too.
