77 KZ 650 rebuild - want to increase cc, how much?
- jwm1120
01 Oct 2008 17:27 #239710
by jwm1120
77 KZ 650 rebuild - want to increase cc, how much? was created by jwm1120
I have a 77 KZ 650. I am currently in the process of stripping it down to rebuild it. I want to bore it out and go bigger. Does anyone know how far I can go? The block is massive, way bigger than it needs to be for those pistons. I had heard it's the same block as the large KZ's use. Does anyone know if that is true? If so, can't I bore it out to the larger engine size and replace the critical bits?
I'm also looking for some horsepower increases for my rebuild if anyone has some tips.
- SLEEPER650
- Thank you received: 2
01 Oct 2008 17:55 #239714
by SLEEPER650
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
Replied by SLEEPER650 on topic 77 KZ 650 rebuild - want to increase cc, how much?
Easyest way is to install a 1980 kz 750e engine and bore it out to 810. the 750 is a direct fit no modifications need to be done to make it fit.
78 650sr my baby
82 kz1100
- jwm1120
01 Oct 2008 18:09 #239716
by jwm1120
Replied by jwm1120 on topic 77 KZ 650 rebuild - want to increase cc, how much?
I guess i want to use the pieces I already have. I'd like to modify those. THat would be ideal for me.
- SLEEPER650
01 Oct 2008 18:15 #239718
by SLEEPER650
78 650sr my baby
82 kz1100
well you could bore out the stock 650 jugs and install a 710 kit or use a 750 jug and bore out the upper case to accept them.
78 650sr my baby
82 kz1100
- RonKZ650
- Thank you received: 240
01 Oct 2008 18:27 - 01 Oct 2008 18:28 #239720
by RonKZ650
Replied by RonKZ650 on topic 77 KZ 650 rebuild - want to increase cc, how much?
A KZ750E uses a completely different charging system than a 77 KZ650 so if you did go the KZ750 routt the reg/rect ect of the KZ750 would have to be swapped over as well, or the 77 KZ650 stator/stator cover/rotor would have to be swapped over to the 750 cases. One of my 650s has stock size GPZ750 Kawasaki pistons in it and it runs real good. That's 740cc I think. I think that's the limit.
Last edit: 01 Oct 2008 18:28 by RonKZ650.
