- Thank you received: 13
Here's One For The Gurus.....
- Sandy
- Fly High,Tony
Actually,it's not the springs that would be difficult to replace,but the keepers.(Obviously)
Setting a socket on the retainer,and giving it a few taps with a hammer can pop the keepers out of place,releasing the retainers and springs,allowing you to get in there to the seals.
I've watched a friend of mine(who runs a repair shop) do this on a few different bike engines(with the head off though),only because it's quicker.He's got the knack.
He still uses the spring compressor to put it all back together.
I want to know how you make out Rick...for future reference,bud.
1977 KZ1000 A-1
- PLUMMEN
- Thank you received: 104
ive never tried anything like that myself,but mechanic in a can works for some people.:laugh: run a couple of quarts of this in there and run the wheels off of it to see if it really helps,youve got nothing to loose and if it does work you will be everybody heroe.and if it doesnt help,just deny ever doing it !:woohoo:Well, Plummen, to my mind stuff like that falls into the "overhaul in a can" school of thought.....but I know you're kidding me cuz you're smarter than that....right ??
Nope, this kind of thing has to be done properly. Anything less is just a bandaid, IMO, so I'll just have to buckle down and get 'er done. Should be an interesting process.
Film at 11.....or as soon as available....hopefully sometime in mid-November or thereabouts....
- MDawnz1
- Thank you received: 27
If you can get it all apart ,, And think you can get it all back together again,,,,,,,,,.....
Oil the seal , then seat it on with a piece of hard plastic tubing .The top of the guides are tapered.
I understand what you are trying to do ,
But man , space is tight in there .
PS . the nylon rope trick lets you walk away for a day or a week without having an air supply hooked up full time.
Best of luck ,
Please let us know ,,
Mike
1974 Z1a, still 903
- 893cv
- Thank you received: 15
This will take you to a drawing of the BMW tool.
www.ascycles.com/detail.aspx?ID=999
It looks like an easy build.
Ride Well,
Jon
1980 kz1000 LTD
1978 Z1R
- H2RICK
- Is this a fun bike, or what!!!
Until I get the cams out, I'll just have to wait and see because I can't make any measurements, etc. I just may "borrow" a scrap 650 engine from work and disassemble it to measure everything up first, then build the tool and then try it out on the scrap engine. That way, if anything gets damaged....no probs.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- Thank you received: 797
- H2RICK
- Sandy
- Fly High,Tony
