rusty cylinders
- zeiss150
If my cylinders (2 out of the 4) on my 78 KZ650 had a tiny bit of rust on them that was deeper than the rest of the bore, say about .oo1 of an inch deeper would that cause my bike to smoke like a freight train? Keep in mind that I did a valve job (lapped the valves and put new valve stem seals)and it seemed to be as tight as a drum. I also put new rings on it. heres a tip, it smoked with the old rings and it smoked the same after the new rings. I honed the cylinder between ring jobs and there was a bit of rust that the hone couldn't get out, but I put it back together any way :pinch:. So is that why its smoking? I'm voting yes! Any thoughts?
Thanks, Matt
- bountyhunter
- Thank you received: 337
- zeiss150
Matt-
- steell
If these pits are in the center of the cylinder vertically, so that the rings travel from above the pits to below the pits, then it's certainly possible (and likely) that the pits are trapping oil then exposing it to combustion heat causing it to smoke.
- saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- zeiss150
the good news is that I got a set of jugs from ebay yesterday so I think I will bore it out (because I have .5mm over pistons)and then I'll be able to start fresh. Any objections?
Thank, Matt-
- H2RICK
- Is this a fun bike, or what!!!
Thank you for that, steell. It's 4 stroke stuff like this that I never think about. 2 stroke stuff I live and breathe, but 4 stroke stuff....well, let's say I just need more experience on overhauls....and hopefully it won't be MY stuff needing the overhaul.:laugh: :laugh:If these pits are in the center of the cylinder vertically, so that the rings travel from above the pits to below the pits, then it's certainly possible (and likely) that the pits are trapping oil then exposing it to combustion heat causing it to smoke.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- zeiss150
Matt-
- donthekawguy
- Thank you received: 8
Hey, UPDATE! I got my replacement jugs from "ebay" so now I have to get them bored over .5 mm (20thou). How much should I expect to pay for a bore job. I got a price off about $200 from my local machine shop but they don't usually do motorcycle jugs. Any advice?
Matt-
I would send them to someone who knows bike motors. I'm sure the local guys can do it but I like the piece of mind getting machine work done by someone I know is qualified and has experience.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- bountyhunter
Matt-
I think it was $75 per hole at the machine shop here.
- bountyhunter
Matt-
I went to the dealer where I got my bike and started shooting the bull with a couple of their mechanics and found out the name of the machine shop they send their heads and cylinders out to. best in the area, you might get similar results.
