one very hot cylinder, not 2 :(....help!!!
- cafe750
- 1978kz750b
78'kz750 drag bars and bad ass front tire...more to come[img size=150][/img]
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- cafe750
- 1978kz750b
- BSKZ650
- Thank you received: 14
my first thought is to reclean the carbs, check the float levels, and reset everything, it may take a second time to get it right.
also check to make sure you have a good fire to the cyls, ie coils etc
77 ltd1000, current rider
76 kz900, just waiting
- cafe750
- 1978kz750b
- steell
I suggest a complete tuneup as a starting point, check/adjust the valve clearances, points and timing advancer and timing, and the fuel level in the float bowls. Then sync the carbs.
750 twin has wasted spark ignition, but if the motor is in good shape you can ground one spark plug wire, start it up, then ride away on one cylinder. I've done it.
- cafe750
- 1978kz750b
- cafe750
- 1978kz750b
- steell
I have flipped them upside down (76-80 750 twin carbs) and set the top of the carb float (actual bottom when the carb is right side up) at 1" from the bowl mating surface. When checked with the hose method the fuel level was perfect.
Synching the carbs with vacuum gauges made a huge difference on my 750 twin.
You don't have to remove the head to check/adjust the valve clearances, just the valve/cam cover. A Factory Service Manual is "highly" recommended
- Thank you received: 2098
... right side exhaust gets very hot super fast ...the bike doesnt have to be running for more than 2 seconds and that right exhaust is too hot to touch....
With engine running, both exhaust header pipes are supposed to very quickly (a few seconds) get too hot to touch.
With engine running, would spray water mist onto both exhaust header pipes and observe what happens. The water spray should instantly sizzle and vaporize if combustion is happening inside the cylinder. Where the water spray does not instantly sizzle and vaporize, and just runs down the pipe, it indicates that combustion is not happening inside the cylinder (for whatever reason).
Should perhaps consider performing the water spray test, and posting the results, which would aid in diagnosis of the problem.
May just need a brand new spark plug of the correct type and size -- and no guessing allowed -- be absolutely positive about using the exact sparkplug specified by the factory service manual.
Would remove leftside plug and hold its base against the cylinder head while spinning the engine over with ignition switch ON (as in normal cranking procedure), and watch for good fat spark. If there's no spark or an extremely weak spark, indicates a problem in the ignition system.
Good Luck!
- cafe750
- 1978kz750b
