Speedo Needle
- 1982ltd
27 Sep 2008 16:06 #238970
by 1982ltd
Speedo Needle was created by 1982ltd
Do anyone have a quick fix for spedometer needle jumping eractically after 100 KM/60MPH. Example, when driving at 110, the needle is jumping between 100 and 115 KM per hour. Thank You!
- MFolks
- Thank you received: 540
27 Sep 2008 18:08 #238984
by MFolks
Replied by MFolks on topic Speedo Needle
Has the speedo cable been pulled,cleaned,re-lubed(with a light grease)and re-installed?
After cleaning look for broken strands of wire on the inner cable as these might be giving the speedo a spurious signal.
- 1982ltd
29 Sep 2008 13:35 - 29 Sep 2008 13:39 #239250
by 1982ltd
Replied by 1982ltd on topic Speedo Needle
As far as I know, It has not been cleaned. But I forgot to mention that it is an electronic speedo on a 1982 KZ 1000 Ltd.
Last edit: 29 Sep 2008 13:39 by 1982ltd.
- Tony
- Thank you received: 13
29 Sep 2008 13:59 #239256
by Tony
Replied by Tony on topic Speedo Needle
Hi 1982ltd,
I moved this thread to the appropriate forum. If you look in the electrical section you will find your thread.
ELECTRICAL
Battery, charging system, ignition system, electrical starter system, ignition switch, lights, turn signal circuit, horn, gages, speedometer, tachometer, etc.
Good luck with your speedometer.
ELECTRICAL
- MFolks
29 Sep 2008 15:06 #239266
by MFolks
Broken or almost broken wire, loose solder connection,possible circuit board problem. All point to opening up the speedo/tach instruments and take look inside.
