Is it normal...
  • TeK9iNe
  • Topic Author
  • What did you do!?!
27 Sep 2008 11:51 - 27 Sep 2008 22:40 #238943 by TeK9iNe
Is it normal... was created by TeK9iNe
...For the stator cover to get so hot that you cant even touch it?
After riding for about an hour or so, I can place my hand against all of the engine covers (tranny, timing, clutch)for a moment, but the stator cover will take your darn skin off!
I replaced the stator with an old used one a week ago. It is not grounding, and is putting out 50VAC from each line at 4K rpm. Rectifier seems to be working fine... battery new and maintaining proper charge...
:blink:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 Sep 2008 22:40 by TeK9iNe.
  • TeK9iNe
  • Topic Author
03 Jun 2009 12:26 #296039 by TeK9iNe
Replied by TeK9iNe on topic Is it normal...
BUMP> Just remembered, I'm still curios about this one...
Stator cover gets blistering hot! Whats up?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
03 Jun 2009 14:03 - 03 Jun 2009 14:04 #296056 by bountyhunter
Replied by bountyhunter on topic Is it normal...
Is it possible the replacement stator is rated at lower current and is getting overworked? That heat is coming from the windings (wire) itself, and I can't think that kind of temp rise could be normal.
Is it possible the original one was a three phase and the new one is single phase? That would make it work a lot harder.
Last edit: 03 Jun 2009 14:04 by bountyhunter.
