clutch cable snapped while riding, please help me
- genesis
26 Sep 2008 07:34 #238745
by genesis
clutch cable snapped while riding, please help me was created by genesis
last night while I was riding home from work on my 76 kz750, my clutch cable snapped. somehow I got the thing home, even through a traffic jam. It was the worst ride I've ever had to make, but did make me more confident in my skills.
The problem I'm having is, I found the replacemen cable at z1. However, apparently the little adjusting screw/bolt (don't really know what to call it) on the handle somehow flew off on the expressway when it happened. Anybody have any idea where I can get a new one, or even what it is called so I can Google it?
This is my primary vehicle right now, so I'm pretty much screwed until I can get it fixed.
- jonnybiker
- Thank you received: 1
26 Sep 2008 10:47 #238774
by jonnybiker
Replied by jonnybiker on topic clutch cable snapped while riding, please help me
That part is simply called a cable adjuster or slack adjuster.Any shop Z1 ent, Kaw dealer , Or indy shop should be able to match one up for you. Jonnybiker
- APE Jay
- Banned
- Thank you received: 58
28 Sep 2008 15:11 #239107
by APE Jay
Replied by APE Jay on topic clutch cable snapped while riding, please help me
If Z1 doesn't have it, check here;
www.flandersco.com/FlanCableSearch.html
- JohnTaylor
29 Sep 2008 17:06 #239293
by JohnTaylor
Replied by JohnTaylor on topic clutch cable snapped while riding, please help
Thats a problem I know all to well. I was able to get one at a kawi dealer. Mine broke late one sat afternoon in the middle of a 2 week tour in far east Quebec. I had to ride another 1000 KM with vice grips as my lever. Good luck
JT
JT
- TeK9iNe
- What did you do!?!
- Thank you received: 28
29 Sep 2008 19:34 #239327
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic clutch cable snapped while riding, please help me
AAARRRRRGGGHHHH!!!
Mine just broke tonight! Cracked back into gear right behind a minivan as I just came to a stop! Freaky!! Had to let as much slack as possible, then vice grip the slack to the handle to get home!
Sucks... I'm getting 2 on wednesday from Z1 since I'm only 2 hrs away.
Screw the riding with vice grips! Its damn nerve racking! I'll never be without a spare again.
J.
J.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Ashbane
01 Oct 2008 18:34 #239723
by Ashbane
1976 KZ750 B1 Twin
Replied by Ashbane on topic clutch cable snapped while riding, please help me
WTF is going on here....?
My clutch cable on my 76 750b1 just broke Monday Night as well.
Ordered a replacement from Z1.
Luckily I had just left the house and only had to push it back 4 blocks.
Do certain phases of the moon cause clutch cables to snap all at the same time or something?
1976 KZ750 B1 Twin
- PLUMMEN
- Thank you received: 104
01 Oct 2008 19:25 #239731
by PLUMMEN
Replied by PLUMMEN on topic clutch cable snapped while riding, please help me
i wonder how much kawasakiman is making cutting partway through those cables for jeff?:laugh: just kidding ,learn how to work the traffic lights is the best advice i can give you.had this happen on a yamaha 500tt years ago had to blow through an intersection cuz it broke when i was trying to stop!:S :dry: :huh: :blink:
- zombiescustoms
02 Oct 2008 17:28 #239857
by zombiescustoms
Replied by zombiescustoms on topic clutch cable snapped while riding, please help me
This is weird, mine broke yesterday on the way to a dentist appt. so thats when I decided to tear my motor apart, don't ask me why but I figured I could not ride it for a few days so I might as well tear it apart!!
- timebomb33
02 Oct 2008 20:27 #239880
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic clutch cable snapped while riding, please help me
do like i do, i always have at least 2 in my race trailer [i lost in the final round one time because mine broke when i was pushing the bike down to the staging lanes if i had another one i could have changed it in about 3 mins] when ever i take a long trip i carry an extra clutch and throttle cable with me i have 7 bikes that take all the same cables so i always have some around i use motion pro cables if you using a superbike bar or a drag bar these numbers should work for most big kawi's with smoothbores or stock carbs use 31-3001 for your throttle cable they are the same for both. for the clutch use 36-3002 if you have higher bars use 36-3006 and for the throttle cables use
use 31-3019. also when ever i do an oil change i pull the cables and lube them.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
03 Oct 2008 13:38 #239965
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic clutch cable snapped while riding, please help me
mAKE SURE YOU INSPECT YOUR CABLES AND LUBE THEM UP FROM TIME TO TIME.
YOU SHOULD ALL BE DOING A WALK AROUND AT LEAST ONCE A MONTH TO CHECK FOR ABNORMALITIES AND FREYED CABLES.
USUALLY THE CABLES WILL BEHAVE SUSPICIOULSY BEFORE THEY COMPLETELY BREAK.
LUBE UP THOSE CABLES AND THEY WILL LAST A LOT LONGER.
tHEY ALWAYS BREAK AT THE HANDLE.
1978 KZ650B
1979 KZ1000ST
- Mark Wing
- Thank you received: 22
03 Oct 2008 17:53 #240024
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic clutch cable snapped while riding, please help me
Hey mine's about to brake too. I had to adjust out the slack three times on the way home but I made it before it snapped.
Mark
Mark
Yorba Linda Cal.
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
17 Nov 2008 18:07 #248016
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic clutch cable snapped while riding, please help me
So is there a way to tell if the cable is about to break?
Mine was adjusted to about 2-3 mm clearance at the lever, but lately it has increased to about 4 mm. I thought as the clutch plates wear, that the slack would be less. I cannot see any freying of the cable near the handlebar lever, but I worry that the cable may be stretching or about to break. I lubricated the cable very well a year ago.
Any advice? Thanks.
Any advice? Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
