headache! chain rubbing
  • Knight Rider
  • Knight Rider's Avatar Topic Author
25 Sep 2008 16:40
#238663
1075 410 cams. stock head but has hd springs
took the head off and the chain was rubbing on the intake side on the bottom by the idler, was making noise like it was a shim problem but found this ...... why is it happpening? chain stretch, idler wear,whats up,have a new head i want to put on,should i get a new chain? if so is a master link system the way to go,dont want to crack the case. i am ambitiously lazy.
1976 kz900 1075 435 cams ported head sidewinder
  • keith1
  • keith1's Avatar
Re: headache! chain rubbing
25 Sep 2008 17:14
#238671
i would guess a stretched chain or a busted component or severely worn component..as far as i know
no master link, going to have to do a tear down...
others might know more........good luck....
  • donthekawguy
  • donthekawguy's Avatar
25 Sep 2008 23:32
#238709
Sounds like the tensioner is bad. You can replace the chain with a master link unit. Try to measure the old one first. Should tear it down to the block and replace all the little parts while your in there.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
28 Sep 2008 10:49 - 28 Sep 2008 10:50
#239074
Yes you can use a riveted style timing chain,so you don't have to split the cases.
Take a look at part #10 in the pic.
A LOT of times,these guides will let go.
And Don...do your frikken laundry!:ohmy:
You might want to pull the pan(get a new gasket)and see what's laying in there.
1977 KZ1000 A-1
Last edit: 28 Sep 2008 10:50 by Sandy.
  • Old Man Rock
  • Old Man Rock's Avatar
28 Sep 2008 18:28
#239117
hahahahahahaha....
Yes indeed but Sandy, your little guy is humping a big letter E so I don't know what's more disturbing...:laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • timebomb33
  • timebomb33's Avatar
28 Sep 2008 19:56
#239135
KNIGHT RIDER you might be lazy but replacing the cam chain is really your best option, if the cam chain is worn out that bad or your idlers are either worn or broken just imagine how much damage could occur if the chain let go. i've broken master links on drive chain before saw what gets messed up on the outside can you imagine what would happen inside if the cam chain let go. besides winter is coming good time to pull it down and do it right.remember the old saying there is always time to do it right never time to do it over. good luck with your problem. :evil:
I THINK MY POWERBAND BROKE
