Piston Rings - 1100
  • kpier998
  • kpier998's Avatar Topic Author
Piston Rings - 1100
24 Sep 2008 20:13
#238546
I priced piston rings for the 1089 (1100) Spectre pistons today and they want $65 per piston :ohmy: at the local shop. Is this about right?
Is there another option or a place online that sells them cheaper?
Thanks.
  • MFolks
  • MFolks's Avatar
Re: Piston Rings - 1100
24 Sep 2008 20:39
#238549
www.redlinecycle.com,www.kzzone.com,www.partsnmore.com,www,dynoman.com,http://vintagecyclepart.com,www.sudco.com,www.oldbikebarn.com just a few places to try............
24 Sep 2008 20:40
#238551
kpier998 wrote:
I priced piston rings for the 1089 (1100) Spectre pistons today and they want $65 per piston :ohmy: at the local shop. Is this about right?Is there another option or a place online that sells them cheaper? Thanks.
Here's a good source.
Click > Z1E
Good Luck! :)
  • PLUMMEN
  • PLUMMEN's Avatar
24 Sep 2008 20:55
#238556
not sure which year you have for sure but it looks like $25 and change for each set(ya need 4)from z1 enterprises.have you measured your bore and pistons to make sure it will clean up with a hone?;)
  • kpier998
25 Sep 2008 06:47
#238591
Good info. I will check with some of these places.
About the size - No I haven't checked any sizes and don't really have the tools. Maybe I should take the parts by a machine shop and get them measured.
You would need some kind of caliper I suppose plus a tool to measure inside the bore, right?
  • PLUMMEN
  • PLUMMEN's Avatar
25 Sep 2008 07:09
#238596
yeah ive got lots of tools,but even i dont have those.wouldnt know how to read them anyway!:blush: :laugh:
  • bountyhunter
  • bountyhunter's Avatar
25 Sep 2008 16:58 - 25 Sep 2008 16:59
#238665
If you have measurable wear to the cylinder walls, you may want to get the rings that are 0.25mm over the ones you have now and shave the ends of them to get a tighter ring seal.
Last edit: 25 Sep 2008 16:59 by bountyhunter.
  • kpier998
25 Sep 2008 19:03
#238685
I didn't know they made longer rings.
I did see that there are three sizes on the Kawasaki pages for the rings. I talked to the parts guy at the Kawasaki shop locally, and he didn't know why there were so many different part numbers either.
I may be slow, but I'm learning. Keep the information coming, I will soak it up.
  • steell
  • steell's Avatar
26 Sep 2008 17:59 - 26 Sep 2008 18:00
#238848
Stock
First Oversize
Second Oversize
That's the three ring (and piston) sizes listed in the parts book.
Stock is obviously stock bore.
First Oversize varies depending on model, some are .010" (.25 mm), while others are .020" (.5 mm). Second Oversize is anywhere from .020" (.5 mm) to .040" (1 mm). 3 sizes is all I have seen listed for KZ's, some models may have more sizes available, I know of other motors that have six or more oversizes listed.
Last edit: 26 Sep 2008 18:00 by steell.
  • bountyhunter
26 Sep 2008 18:36
#238852
I don't recommend getting rings sized anymore than .010" over the piston size. The rings won't hold round very well when compressed by the smaller bore.
The point is the rings are "perfect circles" at their nominal size. If the bore has .005" wear on the walls, standard rings are .005" too small for that bore and +0.010" rings are .005" larger than the worn bore, but the +0.010" rings will squeeze down a bit if you shave the ends of the rings to give the proper end gap (which is about .003" gap per inch diameter of piston) when installed.
