78 kz650 oil change
  • space
  • space's Avatar Topic Author
78 kz650 oil change
14 Feb 2006 15:38
#23851
how many quarts and what weight,for a 1978 kz650.
Thank You
Post edited by: space, at: 2006/02/15 01:43
  • fixer5000
  • fixer5000's Avatar
Re: 78 kz650 oil change
14 Feb 2006 16:25
#23858
i run 20w50 in mine for warmer weather here in the northeast...10-30 or 10-40 is fine too depending on where you live. drain and watch the sight glass when you refill, run it for a few minutes, let it drain back down and fill it to the top on the sight glass. i think they hold about 3.5 us quarts or 3.2 litres when full...steve
1978 kz650b pretty much stock
massachusetts
  • space
14 Feb 2006 18:12
#23898
Thank You.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
14 Feb 2006 20:05
#23958
Welcome Space.
You should try to get yourself a manual at some point to help with your periodic maintenance. Check under the seat for the owners manual in a plastic pocket/flap attached to the bottom of the seat.
As well, search through the Archive section as there has been lots of post on all types of maintenace.
Here's the steps from the manual:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
