Exhaust pipe clearance problem
- Exitpupil
21 Sep 2008 11:53
I have a 79 KZ1000LTD lowered 1" front and rear. My V&H 4 into 1 occasionally drags at the collector in cornering to the right. Are there any exhausts available that tuck under tighter?
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- racer54
Re: Exhaust pipe clearance problem
21 Sep 2008 15:49
What style V&H header do you have? They make about 4 different ones for that bike. I assume it's the upswept model? Most pipes run under the motor then swing out along the right side and then angle up. Not much difference between brands in that style. If you have a style that the collector is off to the right and doesn't sweep up, then you might want to get the upsept style. By lowering the bike, you have taken away a lot of ground clearance. I am in the same spot but I have mine lowered about 2"...short legs. For the most part, it's something you have to learn to live with and take it into consideration while riding.
- Exitpupil
21 Sep 2008 16:29 - 21 Sep 2008 16:31
It is a recent new purchase upswept model.
Are there any twin exhausts, exit on both sides, that are decent? I don't like the turn out style, but a twins going straight back would suit me.
Last edit: 21 Sep 2008 16:31 by Exitpupil.
- PLUMMEN
21 Sep 2008 22:19
i had the same pipe on my ltd with 10-1/2 -11" shocks i feel your pain!put a turbo on there and your clearance issues will be gone!:laugh:
- donthekawguy
22 Sep 2008 04:02
Unless you put a sidewinder on it your out of luck. I had mine lowered 2 inches and needed new shorts the first time I took a corner too fast.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
