Oil Leak From Head Gasket. 1982 KZ550LTD
- maagman
- 1982 KZ550LTD
- Tranny
- RonKZ650
- Thank you received: 240
- Thank you received: 2098
(1) No loose exhaust clamp (loose or stripped, stripped stud, cracked clamp, etc.);
(2) No leaking exhaust gasket.
The goo oozing through a leaking exhaust port may easily be mis-diagnosed as oil leakage from some other source.
If an oil cooler is fitted, would also check integrity of hoses and clamps where attached to the finned cooler.
Good Luck!
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
+1 on the synthetic oil issue.
'85 GPz550(ZX550-A2)
- maagman
- 1982 KZ550LTD
1 - Unknown header and pipe from P.O., pod air filters. Carbs are "vintage takeoffs" that have never been touched. Still have the litle plugs in the adjusting screw holes. Feels like it is running a little lean in the mid to upper rpm range. About 4.5k on this setup, unknown for sure, but guessing about 38k total miles.
2 - Checked the vent tube during lunch break and it is unobstructed. Really thought this would be the problem as the oil gusher came on pretty sudden.
3 - Used a can of the Gunk gell spray and a few bux at the hottest car wash in town this evening after work. Engine is now completly clean and dry. Added an ounce of dye and rode around for 5 or 6 miles, then hit it with the UV light. Hmmm..Engine is still clean and dry. Only found a VERY small seep at one of the #1 exhaust pipe studs, (just the stud, not the pipe inlet), and a little bigger seep that seems to be coming out of the #2 exhaust pipe inlet. All the stud nuts are still tight.
4 - When I ran the valves this spring, I remember the compression being O.K. I can't remember the exact number, but I remember looking it up in the FSM and deciding it was alright.
5 - Running O'Reilly house brand 10-40 oil. Have changed the oil about 12 times in 4500 miles trying to get the dirt out of the motor. When I got it, it had been running for an unknown amount of time without the boots between the airbox and carbs.
I'm gonna try and run it 20 miles or so tomorrow afternoon after I get done with some work around the house and see if a bigger leak presents itself. What I have seen so far doesn't look like what was dripping on the concrete and covering the entire engine every night after work.
In the meantime, any ideas what is causing the seepage at the exhaust ports? Rings or valve guides?
Sorry for the book length post. Just trying to cover all points.
Thanks for the help guys.
... VERY small seep at one of the #1 exhaust pipe studs, (just the stud, not the pipe inlet), and a little bigger seep that seems to be coming out of the #2 exhaust pipe inlet. All the stud nuts are still tight... In the meantime, any ideas what is causing the seepage at the exhaust ports? Rings or valve guides?....
Exhaust Gasket from Z1E
Tight stud nuts aren't necessarliy the answer, because the clamps may bottom and leave the old crush gasket still leaking.
Rings or valve guides? -- don't think so. Because any oil from the combustion chamber (or oil getting past valve guides or valve seals) should be blowing out the end of the exhaust system, and not escaping through the head exhaust port.
On some KZ engines, it's reported that when re-threading or chasing (cleaning) threads inside head where exhaust studs are fitted, a possibility exists whereby the tap may protrude on through into an oil channel lying closly behind the stud hole. In that event, oil may escape around the stud threads to the outside. Could be addressed by stud removal, thorough cleaning, and re-assembly with Permatex high temp thread sealant applied to the threaded area. Am betting against this being the problem in the case at hand.
Good Luck!
- maagman
- 1982 KZ550LTD
Thanks for the help everybody.
