oil running down kickstand?
- jdreadrocker
19 Sep 2008 20:16 #237860
by jdreadrocker
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
72 honda cb500, 2003 Buell Blast P3
oil running down kickstand? was created by jdreadrocker
Well i got the old GPZ750 out the other day to do some tinkering on it and i noticed i have oil running down the kickstand. I have no clue where it is coming from. Any ideas?
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
19 Sep 2008 21:08 #237870
by Skyman
West Linn, OR
Replied by Skyman on topic oil running down kickstand?
I am not familiar with the 750, but if it were a 1000, I'd say it is either coming from the wire grommet going into the stator cover, or from one of the oil seals behind the front sprocket cover.
West Linn, OR
- FastKaw1
20 Sep 2008 02:40 #237879
by FastKaw1
Replied by FastKaw1 on topic oil running down kickstand?
Im also not familiar with 750.
Could be the counter shaft seal, or something as simple as a over oiled chain.
Take the sprocket cover off clean everything up and see.
- bill_wilcox100
- Thank you received: 5
20 Sep 2008 10:46 - 24 Sep 2008 20:01 #237916
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic oil running down kickstand?
Just had this problem. For me it was too much oil in the engine. Oil over flowed via the crank case vent hose directly into the bottom of the Air Filter box.
When I reduced the oil to the right level it continued to leak! :ohmy:
Why? Because the oil had accumulated in the bottom of the Air Filter box, in that small sponge/filter thing at the bottom of the box. Being oil soaked it would have continued to leak down the black drain hose for a long time.
I removed all the parts in the Air Box and cleaned them, cleaned out. Then I cleaned the empty Air Box, put in a new longer hose and changed that sponge/filter for some packing material that was similar that I had hanging around the my shop.
I had originally concentrated on the oil filter cover seal/O-ring for a long time. Cost me lots of oil and oil filters and O-rings till I figured it was not the problem. :blush:
Best of success.
PS:
Please add your year, model and location to your signature. As you have read earlier, it helps fellow members in responding and... its considered real friendly too.
Best of success.
PS:
Upgrades:
Montreal, Canada
Last edit: 24 Sep 2008 20:01 by bill_wilcox100.
- APE Jay
- Banned
- Thank you received: 58
24 Sep 2008 16:46 #238512
by APE Jay
Replied by APE Jay on topic oil running down kickstand?
Never have to worry about a rusty kickstand.:laugh:
- jdreadrocker
25 Sep 2008 16:26 #238661
by jdreadrocker
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
Replied by jdreadrocker on topic oil running down kickstand?
Oil seal is shot! Gota get a new one to stop the oil bleed...Thanks guys!
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
- bill_wilcox100
25 Sep 2008 19:42 - 25 Sep 2008 19:43 #238693
by bill_wilcox100
Upgrades:
Montreal, Canada
Say, jdreadrocker... which seal was it finally?
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 25 Sep 2008 19:43 by bill_wilcox100.
- jdreadrocker
25 Sep 2008 20:03 #238695
by jdreadrocker
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
just from looking at my shop manual and the bike it looks like a bad oil seal that goes over the pushrod in part of the clutch assembly. I'll have to double check it but i believe that is where the oil is coming from. keep in mind i'm still a little green when it comes to fixing these Kawasakis so i could be way way way off. i'm gona try replacing that seal and see where that takes me first.
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
- Wild and KZ Guy
27 Nov 2008 05:21 #249554
by Wild and KZ Guy
A couple of Old School Minibikes
1980 LTD KZ650 E1
Replied by Wild and KZ Guy on topic oil running down kickstand?
Just checking to see how that seal replacement went. Was it fairly easy to get out? Did you fix the problem?
1980 LTD KZ650 E1
