Cam Chain - Original swapped out for APE any tips?
- KOOL RYDER
- KZ 650B2 / KZ 1000E
16 Sep 2008 10:24 #237377
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Cam Chain - Original swapped out for APE any tips? was created by KOOL RYDER
Hey gents:
I am planning on swapping the cam chain adjuster on my stock KZ650 with a replacement from APE.
Any tips or tricks that are required to install this?
KRB)
KRB)
1978 KZ650B
1979 KZ1000ST
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
16 Sep 2008 15:19 #237402
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Cam Chain - Original swapped out for APE any tips?
I have an Ape manual adjuster on my 900, and 650. ONLY finger tighten the bolt until you feel pressure the back the bolt out about 1/4 of a turn. Then tighten down the nut. The directions on the back are pretty good.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
