- Thank you received: 797
use one piece head gasket instead of two piece?
16 Sep 2008 09:18 #237371
by 531blackbanshee
use one piece head gasket instead of two piece? was created by 531blackbanshee
on my 1980 z1r 1000 i am blowing oil out between the head and cylinders in the front center.i was thinking about using the one piece head gasket in place of the two piece that was originaly on there.is there any reason why i should,or should not do it?has anyone ever used one in place of the other?if so why,and how did it work?
tia
tia
- mtkawboy
- Thank you received: 16
16 Sep 2008 09:59 #237374
by mtkawboy
Replied by mtkawboy on topic use one piece head gasket instead of two piece?
I have, worked just fine for the last 10 years. I used "The Right Stuff" silicone around the center, no problems or leaks yet. I believe it was a Cometic gasket. Ive seen copper ones used too.
- Royal1MC
- Is it just me, or is it just great to be on a KZ
16 Sep 2008 12:04 #237386
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic use one piece head gasket instead of two piece?
I currently use the one piece, no problems.
Just don't use the o-ring.
I used Hi-temp gasket sealant, works fine.
Los Angeles, CA
16 Sep 2008 13:14 #237391
by 531blackbanshee
Replied by 531blackbanshee on topic use one piece head gasket instead of two piece?
thanks for the replies.i figured i could,but wanted to see if anyone had first hand experience.i believe i will order the one piece gasket and fill the groove with 1211 and re-assemble.
- Jack
17 Sep 2008 07:40 #237496
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic use one piece head gasket instead of two piece?
We used to fill the o ring groove with epoxy and be done with it. Gaskacinch and 1211 for sealant, no leaks.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- PLUMMEN
- Thank you received: 104
17 Sep 2008 10:29 #237526
by PLUMMEN
Replied by PLUMMEN on topic use one piece head gasket instead of two piece?
Jack wrote:
ditto.the copper gaskets should only be used on motors with o-ringed sleeves or else they leakWe used to fill the o ring groove with epoxy and be done with it. Gaskacinch and 1211 for sealant, no leaks.
- School Teacher
17 Sep 2008 10:48 #237531
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic use one piece head gasket instead of two piece?
how does one o-ring a sleeve?
1980 kz1000G1
17 Sep 2008 12:42 #237538
by 531blackbanshee
you actually o-ring the block around the sleeve.
i have ordered the copper head gasket.
plummen- do you know for a fact that it will leak without o-rings even with the 1211 and an overnight cure?
i appreciate the replies and any insight that can be added.
- PLUMMEN
17 Sep 2008 21:20 - 17 Sep 2008 21:53 #237580
by PLUMMEN
top of sleeve recieves the o-ring.only time ive used the copper head gaskets has been on high compression motors(13:1 or so)and turbo motors .on my 1st 1170 i built back when they were considered a big motor :laugh: i didnt listen to the old guy who did the machine work and ran copper gasket without o ringing and it leaked like a sieve!since then ive always had my sleeves cut for o-rings on any high end stuff where i use copper gaskets without a leak,ido spray them down with copper coat also before installing;)okay its actually the area where sleeve and cylinder meet,i still consider it to be the sleeve!:laugh:
Last edit: 17 Sep 2008 21:53 by PLUMMEN.
18 Sep 2008 09:45 #237622
by 531blackbanshee
ok gotcha plummen,thanks for the reply.
so now,crap!
whatta do?????????
(scratchs head looks off into space-where most of my inspiration derives)
so now,crap!
whatta do?????????
