New mac exhaust system "HTS" paint cracking
- krazykat
11 Sep 2008 21:33 #236803
by krazykat
77 KZ-750 ~10k original miles and a few tweaks
New mac exhaust system "HTS" paint cracking was created by krazykat
I have less than 50 miles on a mac HTS with chrome muffler exhaust and the coating on the headers is already starting to go. It's cracking at the top of the down pipes near the head.
Anyone else experience this? I've contacted mac and am waiting for a response. They had to make the exhaust up when i ordered it because it wasn't in stock, so maybe the coating wasn't properly cured or didn't have time to dry/set up...?
I guess I should have gone all chrome. I'm suspecting they're going to tell me it's my fault or the bike's fault. If that happens there is a coating place near me that I've had work done by and they could do it for pretty cheap. Their turbo-x coating has withstood 2k miles on a turbo rotary, so I don't think a KZ will be much of a challenge for it.
- krazykat
12 Sep 2008 12:01 - 13 Sep 2008 11:49 #236863
by krazykat
Replied by krazykat on topic New mac exhaust system "HTS" paint cracking
here are some pics, you can click on the image and then choose full screen:
This is not heat related, but it arrive well packed with this damage already done:
Last edit: 13 Sep 2008 11:49 by krazykat.
- krazykat
02 Oct 2008 06:57 #239787
by krazykat
Just to update: I received a UPS tracking number from MAC today, so I guess they're sending a replacement header set.
- andy22285
05 Oct 2008 18:15 #240303
by andy22285
Replied by andy22285 on topic New mac exhaust system "HTS" paint cracking
what do you have your system on? how is it other than the paint issue?
- krazykat
06 Oct 2008 18:33 #240462
by krazykat
KZ-750 twin
I like it other than the paint issue. It's a little raspy. I'm going to fix that with some stainless steel wool packing.
The only thing I don't like is that it partially blocks the oil drain... Maybe it just needs a little adjustment, since it's slip joint construction.
- andy22285
06 Oct 2008 19:35 #240477
by andy22285
is that the two into one system? if so do you have a pic of the system on the bike?
- krazykat
07 Oct 2008 15:39 #240643
by krazykat
Yep, but I'd get the 2-2 chrome if I did it again as it's not much more and looks cleaner IMO. I just got the chrome replacement pipe today. Looks good.
I'll get some pics this weekend.
- HansNOR
07 Oct 2008 15:58 #240646
by HansNOR
o 198x Kawasaki GPZ 750 (year will be updated)
x 1981 Kawasaki KZ 650 SR
Replied by HansNOR on topic New mac exhaust system "HTS" paint cracking
i got a 4-1 mac exhaust in all black -- after the first ride the paint was cracking and it started rusting .. now i've removed rust and re-sprayed it with rattle can heat resistant paint. . . hopefully that will work better
- krazykat
07 Oct 2008 18:22 #240669
by krazykat
I'd try curing it in moderate heat for a while. I've heard it needs to be baked/cured to hold up well.
I've heard there is some stuff you canget in a rattle can that you actually cure with a propane or mapp gas torch after it has air dried. Works well on turbos and downpipes.
In the end, you get what you pay for.
- MDawnz1
- Thank you received: 27
07 Oct 2008 20:19 #240705
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic New mac exhaust system "HTS" paint cracking
Paint the INSIDE of the pipe with Hi Temp paint .
Grab the top off of something like WD40 with the tube on it and spray in as far as you can .(use with the paint)
Black ,,NO cracking ,,
Chrome ,,NO bluing ,,
It works
It works
1974 Z1a, still 903
