Loctited case bolts?
- Mike W.
11 Sep 2008 14:59 #236726
by Mike W.
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
Loctited case bolts? was created by Mike W.
I need to put a new clutch cable on my #2 bike (99 kz1000p). In trying to turn the bolts that hold the sprocket cover on, I was met by a total lack of bolt motion. Sure feels to me like the previous owner red-loctited those things. I tried hitting the end of an Allen wrench with a hammer while it was in the bolt, but to joy. Anyone have any ideas?
Mike
Mike
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
- MFolks
- Thank you received: 540
11 Sep 2008 16:26 #236744
by MFolks
Replied by MFolks on topic Loctited case bolts?
Try a hair dryer at high settings just be careful around paint and plastic parts. Apply heat and try again. If the bolts are not held in with Loctite they just might be stuck with corrosion(steel bolts in an aluminum case, sounds like dissimilar corrosion)
When you get them out and before re-installing the bolts get some silver anti-seize and apply a little to the threads(it will be easier to remove next time). The auto parts store sells permatex anti-seize in a tube.
- Mike W.
12 Sep 2008 02:24 #236815
by Mike W.
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
Replied by Mike W. on topic Loctited case bolts?
Thank you. The setting where bolts were would have made heating quite a challenge. After dinner last night, I was ready to just break the bolts off and put new ones in. I applied WAY more torque to remove them than I thought the bolts would take and everyone of them did break loose. You were right... just frozen in place. I don't have to head down to VA to track someone down for using red loctite on a case bolt:) Thank you again.
Mike
Mike
2 x \'99 KZ1000P
96 XR400
99 Beta Rev 3
- coppertales
12 Sep 2008 10:46 #236858
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Loctited case bolts?
Fire up the engine and let it get good and warm......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
