- Thank you received: 28
Piece of starter idler gear socket chipped :(
- TeK9iNe
- What did you do!?!
10 Sep 2008 11:48 - 10 Sep 2008 11:54 #236563
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Piece of starter idler gear socket chipped :( was created by TeK9iNe
Hi all,
I've got a potentially big problem...
Under the alternator/starter clutch cover, there is a small socket that holds the idler gear between the clutch gear and starter gear.
Well... The socket on the engine side is chipped away at the bottom. I took out all of the minute bits of debris and matched them up to make sure nothing got into the pan.
The gear shaft still fits snug in there, and with the cover on, everything operates ok. Even popping the starter aggressively on-off-on doesnt come loose or even make a sound.
The big Q though... will this pass a safety!?!The bike is bein safetied in 2 days, and the clutch damper ring has to be replaced... :blink:
Thanks.
J. :dry: :huh:
Thanks.
J. :dry: :huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 10 Sep 2008 11:54 by TeK9iNe.
- TeK9iNe
13 Sep 2008 11:30 #237006
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Piece of starter idler gear socket chipped :(
Whew! I'm such a nervous goofball!
Everythings cool....
Hittin' the streets on Monday!
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- mark1122
- Keep twisting it
- Thank you received: 109
14 Sep 2008 12:14 #237115
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Piece of starter idler gear socket chipped :(
u should be fine on the safety.They will not take the covers off the motor. Whats a clutch damper ring?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TeK9iNe
16 Sep 2008 13:10 #237389
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
A clutch damper ring is a small metel ring with one side of it that protrudes and is coated with hard abs-like rubber.
It brings the starter clutch gear to a stop once the engine revolutions become faster. (and you release the starter)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
