cam chattering KZ1100
  • cary
  • cary's Avatar Topic Author
13 Feb 2006 18:31
#23651
Changed out the plugs and ran some seafoam (hi-potency carb clear additive) on my bike last week and now it runs great, but making audible vibration noise from the left side of the valve cover area. Is this a potential BIG PROBLEM? What could cause this and how can it be fixed?
  • cary
Re: cam chattering KZ1100
13 Feb 2006 18:31
#23652
carb cleaner... oops
  • wireman
  • wireman's Avatar
13 Feb 2006 19:04
#23670
where did you run the seafoam?
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
13 Feb 2006 20:18
#23709
This noise started after the Seafoam treatment?
Get right or get left! <*{{{><
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
14 Feb 2006 05:58
#23768
Suggest listening around with a stethoscope or stick to narrow down location of noise.
Is it pre-ignition? (run on three to see)
Reed?
-Duck
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
14 Feb 2006 15:01
#23845
I can't se an additive causing the problem. Could be coincidental that something broke. I would remove valve cover and have a look. Something loose or broken in top end can be a major problem.
  • cary
14 Feb 2006 16:29
#23859
ran it in the gas 1/3 bottle to a tank, with new plugs
